23269 Discussions
Problem with quality of image (Samsung monitor). Problem with drivers for i3-10100?
Piotr
Dear Intel Community,
I have question. I want to know where are stored settings for display. My system Windows 10. I plugged my monitor to another computer. When I returned to my computer and I plugged this same monitor I have problem now with quality of image (letters are not black, everythigs are grey). If it is possible that another computer did changes in monitor settings (firmware) and now I have problems? I did factory reset of my display but this doesn't help. Monitor can change display settings in Intel drivers or it is not possible? I want to reset all settings to default in drivers, system. Can you help?
Yours faithfully,
Piotr
David_G_Intel
Thank you for the update, we will close the thread now.
David G
AlHill
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Piotr
I am not 100% sure if problem is exist. This was my feeling but maybe everything is fine. I only want to know where I can reset all graphic and display settings for display. In Display (monitor) I returned settings to factory defaults but now I must know what should be next step for drivers and system settings. I want to have all factory settings.
I noticed only that I have some erros on Windows Event but these errors was also when my display worked well:
Device .... had a problem starting.
Driver Name: oem19.inf
Service: igfx
Lower Filters:
Upper Filters:
Problem: 0x0
I hope that Intel support engineer will answer me. How I can reset all settings to factory default for display (color, gamma etc.) both for Intel drivers and OS.
Can you explain me how monitor connect with graphic card? I must know if I will do some changes for settings like brightness or other like gamma and next I will plug this monitor to other PC this monitor will be have this same settings or not? Monitor save their settings in firmware storage or something like that?
David_G_Intel
Hello Piotr
Thank you for posting on the Intel️® communities. We need more information from your system to provide recommendations, please share with us the Intel® System Support Utility (Intel® SSU) results:
David G
Intel Customer Support Technician
David_G_Intel
David G.
Piotr
I don't need assistance anymore because I sold this processor. My friend is happy and it work in his PC fine.
David_G_Intel
David G
