23813 Discussions
Problema HD Graphics 530
LMisu
Ho un asus n552vx con una intel 530 hd ed una nvida 950m. Quando mando il pc in sospensione e lo riaccendo, ogni volta che inserisco un dispositivo usb, un jack audio, scollego l'alimentatore ecc, i colori si sfalsano diventando quasi tutti sul blu. Driver entrambi aggiornati problema continua a persistere. Soluzioni?
AlHill
You should use ONLY the drivers from ASUS for both Intel and nvidia on your device, and not use the Intel generic drivers.
Doc
LMisu
So, i can't use nvidia geforce experience to upgrade the nvidia?
AlHill
The problem is, on a device such as yours, both the Intel driver and nvidia driver are modified/customized by the vendor (asus or an asus 3rd party) to provide the functionality and switching needed. Neither the intel and nvidia generic drivers will not work properly.
Your best advice will come from asus regarding the intel and nvidia drivers they provide.
Doc
LMisu
I’d tried without succeeding. Same problem. 😞
AlHill
Then you must contact ASUS. ASUS is responsible for support of your device and the drivers they provide.
Doc
LMisu
Ok. Ty! 🙂
