22849 Discussions
Problemas con controladores intel HD graphics 3000 de 2da generacion
ORami4
hola comunidad, tengo una vit m2420,tengo problemas con los controladores intel HD graphics 3000 2da generacion procesador i3, el problema que presento es que cuando instalo la version de controladores 15.28 la pantanlla de boot de windows inicia pero luego de eso se queda negra quisiera saber si los controladores poseen errores o el problema de mi laptop ya que deseo poner windows 10 y necesito esa version de controladores para que se vea la pantalla en su mejor condicion, espero pronta respuesta de su parte gracias comunidad
n_scott_pearson
Sorry, but Windows 10 is not supported on 2nd generation and earlier processors or their corresponding chipsets. What this means is that Intel is not providing drivers for Windows 10 for this hardware. While Windows 10 should still install and run, it will do so using Microsoft's Compatibility drivers. Microsoft provides these Compatibility drivers as-is, meaning that, if they work, great, but if they do not, your only recourse is to upgrade your hardware.
Reality bites,
ORami4
Pero me pasa lo mismo con windows 8.1, solo funciona windows 7 con procesadores de 2ª generación ?
n_scott_pearson
I am not sure of the answer to this question. Based upon what I am seeing (and not seeing) in the Intel Download Center, there appears to be support for 32-bit Windows 8.1 but not for 64-bit Windows 8.1 (I see only Windows 8 and Windows 7 drivers). See here: https://downloadcenter.intel.com/product/81500/Intel-HD-Graphics-3000.
You could try installing the Windows 8 driver. It is available here: https://downloadcenter.intel.com/download/24971/Intel-HD-Graphics-Driver-for-Windows-7-8-64-bit?product=81500
Hope this helps,
ORami4
Puedes ayudarme a conseguir la version 8 de 64 bits, ya que solo consigo 8.1 ?
ORami4
n_scott_pearson
I gave you link to this driver package in my last message.
