23784 Discussions
Problems with an intel Driver
Inablackwood
Hello! I'm having a weird issue with a graphic card belonging to a hp laptop (serial number hp 250 g7) wich has an Intel® UHD Graphics 620 ( See product here: https://www.neobyte.es/portatil-hp-15-250-g7-i3-1005g1-8gb-512gb-8129.html ).  Theorically the driver needed is the following: https://downloadcenter.intel.com/product/126789/Intel-UHD-Graphics-620 but when I am installing it it dispays an error: "This installation package is not supported by this processor type".
I have no clue in what might have gone wrong, and I also tried several drivers from this website: https://support.hp.com/es-es/drivers/selfservice/hp-250-g7-notebook-pc/24381316
Hardware Id is the following:
PCI\VEN_8086&DEV_8A56&SUBSYS_86C1103C&REV_07
PCI\VEN_8086&DEV_8A56&CC_030000
Any help would be appreciated, thanks in advanced.
I
David_G_Intel
Hello Inablackwood
Thank you for posting on the Intel️® communities.
We need more information to identify the cause of this problem. Please share with us the following information:
  • Which driver versions did you try?
  • Which version of Windows do you use?
  • What is the model of the processor?
  • Is this error showing with both the Intel and HP drivers?
  • Which graphics driver do you use right now?
I will send you an e-mail to the e-mail address associated with your community profile requesting some reports that may contain sensitive information.
David G
Intel Customer Support Technician
David_G_Intel
Hello Inablackwood
Were you able to check the previous post?
Let us know if you still need assistance.
Best regards,
David G.
David_G_Intel
Hello Inablackwood
We have not heard back from you, so we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Best regards,
David G.
