23734 Discussions
Problems with h264 video display
Hello
I am developing an application that receives and displays a stream from a network camera.
Updated the graphics driver in the environment that was working normally until now. Then I encountered a phenomenon that the application hangs when stopping or starting h264 stream display.
Running the html sample we created in the same environment causes IE to stop working in a few hours. At that time, the error log of ntdll.dll is recorded in the event log. If I change the graphics driver back to the old version, no error will occur.
Please tell me what is going on. This is a very big problem.
Finally, I will describe my environment. Also attach the sample html and some files, the results of SSU.exe.
- OS: Windows Embedded Standard 64-bit (6.1, Build 7601) ServicePack 1
- DirectX Version: DirectX 11
- Video Card: Intel HD Graphics 4000
- Driver Version:
No problematic version: 10.18.10.3958
Problematic version: 10.18.10.4425 - 10.18.10.4885
Thank you in advance.
ps. I apologize for my poor sentences.
Hello Hiro-miz
Thank you for joining the Intel Community Support
To further assist you, I sent you a private message.
Wanner G.
Hello.
I will report the results of the subsequent investigation on this question.
I made the same question to the intel embedded community according to the advice.
In the intel embedded community, I received advice to investigate whether the same phenomenon occurs even if the environment is changed.
So I prepared a laptop for Ivy Bridge.
I performed the same test with the following specs, it also occurred in standard Windows.
So I decided to ask questions again in this community.
Test PC spec:
Model: HP ProBook 4540s
CPU: Intel Core i 5 - 3210 M 2.5 GHz
RAM: 4 GB
Graphics: Intel HD Graphics 4000
OS: Windows 8 Pro 64bit (clean installation)
I applied version 10.18.10.3958 of intel graphics driver to the above PC and executed the attached HTML as the first post.
Then, the phenomenon that IE stops occurs.
I applied version 10.18.10.4885, but IE will stop in the same way.
What should I do in order to find the cause of the problem?
Reference URL:
https://embedded.communities.intel.com/message/21537 https://embedded.communities.intel.com/message/21537
thanks.
Hello Hiro-miz,
Keep in mind that in this forum we support different Intel products such as Intel® Processors, Intel® Compute Sticks, Intel® NUC kits, among others. Because you are developing an application, you should contact another community.
Please refer to the Developing Games & Graphics on Intel community below:
https://software.intel.com/en-us/forums/developing-games-and-graphics-on-intel
Wanner G.
