23771 Discussions
Provide peak Tensor throughput performance numbers for GPUs
elevated_quark
The title is pretty much the ask.
I'm a Machine Learning engineer, and evaluating Intel's GPU offerings for Deep Learning work (small-medium scale experiments).
Please provide peak Tensor throughput performance numbers for the following:
1. FP32 FLOPS
2. FP16 FLOPS
3. BF16 FLOPS (also whether or not it is supported)
None of this information is available from a credible source as of writing.
Andres_Intel
Hello elevated_quark,
Thank you for posting on the Intel®️ communities. I know how important is or you to know about the FLOPS, I will be happy to help you.
To understand your request as clear as possible, answer the following question:
  • Are you looking for this information for a specific product? If so, let me know the model.
Andres P.
elevated_quark
Arc A770 and A750
Andres_Intel
Thank you for your response, and for the information provided.
I will start with an investigation to provide you with the information you need, as soon I have it I will let you know.
Andres P.
Andres_Intel
Thank you for your time.
We have been working on the investigation of your request, now I have a couple of questions for clarification, please answer them:
  • Are you referring to Tensorflow as the tool you are using? Or are you using a different tool specifically?
For more information about Tensorflow:
Intel® Extension for TensorFlow.
Running TensorFlow* Stable Diffusion on Intel® Arc™ GPUs
Andres P.
elevated_quark
Hi Andres,
The information I'm looking for, is independent of what tool is used.
I'm asking for the "peak Tensor FLOPS performance" numbers for Arc A770 and A750 at an architectural level and utilization.
If you need an example, here's one: https://www.nvidia.com/content/PDF/nvidia-ampere-ga-102-gpu-architecture-whitepaper-v2.pdf
Again, I'm not looking for a full-blown whitepaper, only the TFLOPS numbers.
-K
Andres_Intel
Thank you for your explanation and clarification, that helps a lot.
Now, I will continue with the investigation to provide you with the information that you need as soon as possible.
Andres P.
Andres_Intel
Thank you for your wait time and patience.
We have been working on the investigation, for Arc GPUs, the online manuals. Check 'Volume 4 - Configurations' and download the PDF. This volume provides device attributes, including FLOPS/Clk for Half Precision and Single Precision on page 7. From that the TFLOPS can be calculated.
Another source of public information is the , section “oneAPI GPU Optimization Guide”. On that page you will find a table of “Xe Configurations”, with FLOPs/clk for single-precision and half-precision, including for the A770 and Data Center GPU Flex 170. Again, from that TFLOPS can be calculated.
Wikipedia also has a lists TFLOPS in an easier-to-read table although the sources can't be verified but can serve as a baseline for subsequent TFLOPS calculations.
Let me know if you have further questions
Andres P.
Andres_Intel
Were you able to check the previous post? Remember to check the online manuals, oneAPI GPU Optimization Guide, and Wikipedia for FLOPS information.
Andres P.
Andres_Intel
Andres P.
