23733 Discussions
Refresh Rate
Ovasuni
Hi!
I had this problem where when I plugged-out or in my Charging cable, my refresh rate always reset to 40hz, I always had to open the intel panel and put it back on to 60hz again 😞
If do you know how to fix it please respond to my messages, and if you do you're an angel.
peace ❤️
Emily
Hello Ovasuni,
To be able to further assist you, I request some additional details, such as:
  • Display driver version
  • GPU (or CPU if using integrated graphics)
  • System in use
In the meantime, you can try reinstalling the display driver, which is done as follows:
  1. Open Device Manager (can be searched for in the Start Menu)
  2. Navigate to Display Adapters
  3. Locate the relevant adapter, and double-click it
  4. Navigate to the driver subheading
  5. Select to uninstall the device, accepting any prompts
  6. Reboot your machine
  7. If necessary, on reboot, enter Device Manager and click "Scan for hardware changes"
Hope this helps, I await your reply
-Emily
