22896 Discussions
Regarding Intel's i5 11400 UHD 730 iGPU Issue
Sadaf
Recently I have purchased the intel i5 11400 and was planning to run some low spec game like Valorant on UHD 730. But after running that game, there's so much lagging and stuttering which made this game unplayable. I have installed the latest graphics drives and kept all other drivers up to date but still no improvement.
Labels (2)
AlHill
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
[Windows 11 is the new Vista]
Sadaf
Here's the attachment which you've asked for.
AndrewG_Intel
Hello @Sadaf
We understand that you have opened an internal Web Ticket with us regarding the same environment and same issues so we will continue to help you through that channel now. We will therefore close this community case in order to avoid duplication of efforts. Thank you.
Andrew G.
Asystole
Are there any fix? I'm having these issue. I can't play any game without sudden drop of fps to 1.
