22949 Discussions
Resizable BAR not available, required for Intel Arc A370M (missing in BIOS) Envy 16
energyx
Product: HP ENVY 16 Inch Laptop PC 16-H0000 (534C7AV)
Operating System: Microsoft Windows 11
Whenever the ARC A370M card is activated in Windows for an application, I have a short stutter in performance and a reset message in the Windows Logs: The Intel(R) Graphics System Controller Firmware Interface is being reset.
This is most noticeable when audio is playing and there is a short freeze and stutter when the discrete GPU is activated.
Intel stresses that Resizable BAR is required for this GPU, yet HP has not implemented it on a $1000+ laptop.
https://www.intel.com/content/www/us/en/support/articles/000094704/graphics.html
"Set default settings on BIOS, but remember to enable Resizable Bar, as this is fundamental for proper Intel® Arc™ Graphics operation."
This issue has happened with every version of the Intel driver and BIOS levels since purchasing the laptop in February 2023.
I am running the latest BIOS F.31 from December, ARC A370M 31.0.101.5186 and there is still no option to enable this setting. Model 63U42UAR#ABA
Is this issue caused by the lack of Resizable BAR or something else?
Error in Windows log every time A370M is activated
GPU-Z showing lack of Resizable BAR
A similar spec Lenovo laptop with the same CPU and GPU does not have this issue and shows Resizable BAR enabled.
Senkuchan
Valued Contributor II
Double-check if the Resizable BAR is indeed disabled using the Intel® Arc™ Control Software. You can refer to these links:
https://www.intel.com/content/www/us/en/support/articles/000093975/graphics.html
https://www.intel.com/content/www/us/en/support/articles/000090831/graphics.html
Still, have you contacted HP about this issue? Because maybe they have some suggestions on how to enable it.
franciscomnunes
Same here!
I believe this is on HP's side though. I've searched around but haven't really found any clarifying information.
Let me know if you find something!
Francisco
