23586 Discussions
Resolution 3440x1440 on Intel UHD Graphics 630 does not work
LHC3400-UWQHD-100-C
Hey,
it is not possible on my Windows 10 System to select the above resolution -  I use the following Hardware:
Monitor: LHC3400-UWQHD-100-C
Graphic: intel UHD 630 (actual driver installed)
Connection HDMI 2.1 cable
The maximum resolution provided in Windows is 1920x1080.
How do I realise the resolution 3440x1440?
Additionally, the intel graphics control panel does not start properly (several times deinstalled an reinstalled). The blue windows opens and thats it.....
Any ideas?
Yours, Marcus
Maria_R_Intel
Hello LHC3400-UWQHD-100-C,
We noticed that you have contacted Intel® Customer Support directly regarding the same issue here described and we found out that you have an internal support case open. In this case, we will proceed to close this thread to avoid duplication of effort and the support will continue through the internal case where we are already investigating this.
Maria R.
