23560 Discussions
Resolution issue with intel UHD Graphics 770
Technado
I have a Dell OptiPlex Micro 7010 that is having resolution issues, it won't display ultrawide resolutions only shows up to 1080p but if I uninstall the intel driver and go back to Microsoft basic display driver the resolution is there and usable, have tried a complete re install of windows, the latest intel and dell display drivers no change, have all the latest firmware updates for pc and screen. The screen in question is a LG 29WQ500-B and screen is connected via hdmi, have also tried different hdmi cables with no luck.
captain-miffo
Ive got the same problem 🙂
ACarmona_Intel
Hello Captain-miffo,
We greatly appreciate your posts in our Intel communities as well. As there will be differences between your device and Technado, kindly open a new ticket so that we may properly support you as well.
Link to where you may contact us and create a ticket:  Intel Support.
Carmona A.
MUC
Honored Contributor I
Apparently Dell has decided not to offer a higher resolution via the integrated HDMI port.
So this is a limitation on Dell's part, even if it still works with the Microsoft Basic Display Adapter driver.
You should connect LG 29WQ500-B via DisplayPort for 2560 x 1080.
captain-miffo
Well, ive only got two displayports. Dell 7000 Micro.
Technado
I forgot to add, I have tried a display port to hdmi converter that apparently had the ability to output up to 4k, as the monitor only has hdmi input but no change
MUC
Could you specify the converter and provide a link to where you purchased?
Technado
It didn't solve the issue so would be no point buying one
MUC
However, it might help to understand the problem if you tell us which adapter exactly you tried.
Technado
ACarmona_Intel
Hello Technado,
Thank you so much for posting in our Intel communities.
We understand that you are unable to get a higher screen resolution when using the Dell OptiPlex Micro 7010.
According to the specification of the OptiPlex Micro Form Factor 7010 (Page 21), HDMI 1.4b supports 1920 x 1200 at 60 Hz, while DisplayPort 1.4a supports 4096 x 2304 at 60 Hz.
Therefore, you can use the DP port of the computer if you want to use a higher screen resolution.
Furthermore, we recommend that you please contact DELL technical support (1-800-88-0022) to verify the supported resolution of the computer.
In addition, please refer to the following links for additional troubleshooting steps and follow the instructions provided there:
Thank you, and have a great day!
Carmona A.
ACarmona_Intel
Hello Technado,
We are checking in with you on the Dell OptiPlex Micro 7010 issue we are having in case you have any additional queries or require further explanation. Please know that we would be happy to assist you if you have.
Carmona A.
RLM
You can't even type an accurate phone number, how could you possibly know what you're talking about.  Phone numbers are 7 digits not 6 Carmona
MUC
This adapter is described by the manufacturer as suitable for up to 3840 x 2160 @ 30 Hz. This corresponds to a bandwidth of 9 Gbps. Theoretically, this is easily enough for the requirements of the LG 29WQ500-B monitor.
It may be that this adapter leads to limitations due to the way it works (DP++ Level Shifter > HDMI 1.4 300 MHz TMDS). Please try the remedies suggested by @ACarmona_Intel.
To transfer the OptiPlex Micro 7010's HBR2 output to HDMI, there are other converter cable solutions available that you can try. These contain a chip that actively converts the transmission protocol, for example:
CAC-1082
or
CAC-1087
This would be sale or return if it doesn't work.
ACarmona_Intel
Hello Technado,
Carmona A.
ACarmona_Intel
Hello Technado,
We are checking in with you on the Dell OptiPlex Micro 7010 issue that we have, as we have not heard any response from you.
Carmona A.
ACarmona_Intel
Hello Technado,
We have not heard back from you, so we will close this enquiry now. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Thank you, and have a great day ahead.
Carmona A.
