23269 Discussions
SW Jedi survivor graphics problem with Iris XE
AlexVindex
Greetings!
I have serious graphic glitches in Star Wars Jedi Survivor with Iris XE despite recent installed beta driver (31.0.101.4335) have support of this game in the notes. Every texture have red-orange shimmer around them. All graphic settings are on low positions. I've already had similar issues in the past in games Elex 2 and Uncharted 4. In Elex 2 I solved this by disabling dynamic lightning and DOF. And only DX12 version of Uncharted 4 had this problem (so I stick with DX11 exe-file).
Any solution for this in SW Jedi Survivor?
Carlos_L_Intel
Hi AlexVindex,
Thank you for posting on the Intel® communities. I'm sorry for the inconvenience this might have caused you. Please help me with the following information in order to assist you:
  • Are you using a straight cable into the port, or are you using any type of adapter or docking station?
  •  When did the issue start? Were there any recent changes?
  • Can you share a video or screenshot of the video settings?
  •   To get more information from your system, please install the Intel® System Support Utility (Intel® SSU): https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". Click on "Next", save the report and attach it to your response.
Carlos L.
hkooiks
I'm having the same issues as above.
Carlos_L_Intel
Hi @AlexVindex,
Were you able to check the previous post? Let us know if you still need assistance.
Carlos L.
Carlos_L_Intel
Hi @AlexVindex,
We have not heard back from you, so we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Carlos L.
