- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
I have computer with Intel Graphics 630 card. When I connect HDMI cable to Samsung monitor XL2370HD (1920x1080), I can't see all desktop. Desktop is stretched and picture is not good. Driver settings are 1920x1080 with 60 Hz. How can fix this?
- Marcas:
- Intel® HD Graphics
Link copiado
8 Respostas
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Izi,
I understand you are getting issues with picture quality in your computer.
Let me apologize for any inconvenience this issue may be causing to you.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
If possible attach a screenshot/picture showing the issue you are having.
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Fred D.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello!
Thank you for quick respond.
Here is picture (some parts of desktop is missing) and computer configuration.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Izi,
Thanks for the information you sent to me.
I would like you to try updating the graphics driver. You can download latest graphics driver from this link https://downloadcenter.intel.com/download/27058/Graphics-Intel-Graphics-Driver-for-Windows-15-46-?product=98909 https://downloadcenter.intel.com/download/27058/Graphics-Intel-Graphics-Driver-for-Windows-15-46-?product=98909
If issue persists I would like you to install monitor driver from this other link http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=US&CttFileID=3015198&CDCttType=DR&ModelType=C&ModelName=LS23ELNKF/ZA&VPath=DR/201005/20100531095256218/SMXL2370HD.exe http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=US&CttFileID=3015198&CDCttType=DR&ModelType=C&ModelName=LS23ELNKF/ZA&VPath=DR/201005/20100531095256218/SMXL2370HD.exe
In case issue persists please try changing some Scaling options from the Intel® Graphics Control Panel. I attached a screenshot showing the settings I would like you to change on the Intel® Graphics Control Panel. The settings are located under the Display option.
Let me know if issue persists or not.
Fred D.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello!
I was updating both drivers and it did't fix the problem.
Any other solution?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Izi,
Did you try changing the Scaling setting on the Intel® Graphics Control Panel?
If possible please try changing the "Screen Fit" setting on the settings of the monitor. This link on page 38 will show you how http://downloadcenter.samsung.com/content/UM/201006/20100621105808718/BN59-01101A-01Eng.pdf http://downloadcenter.samsung.com/content/UM/201006/20100621105808718/BN59-01101A-01Eng.pdf
Fred D.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello!
Screen fit setting helped me with sreen resolution. Blurry fonts are still there. How to fix that?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Izi,
I am sorry to hear you are still having issues in your computer.
Have you tried using Windows 10* ClearType feature? This link will show you how to enable it https://www.windowscentral.com/how-make-text-easier-read-using-cleartype-windows-10 https://www.windowscentral.com/how-make-text-easier-read-using-cleartype-windows-10
If issue persists please try the Auto Adjustment feature on the monitor settings.
The content on the above site is not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel for the merchants or services offered there.
Fred D.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Izi,
I was wondering if you still need assistance regarding the blurry fonts you are getting in the computer. In case you still need assistance just let me know.
Fred D.
Responder
Opções do tópico
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
