23755 Discussions
Sound stops working after intel iris xe driver update
2andromeda
Dell 5420, i use the audio input jack for external speaker because the alaptop speakers are you know, just not sufficient, now it doesn work, it ony works when i unplug it and. I think its hdmi audio related, i saw the graphics driver uninstall the hdmi audio driver for whatever reason, im sure it needs updatig, but can you guys do it without messing up my regular sound? Thanks.
2andromeda
After a bunch of shutdowns and resets nothing worked until I shutdown holding the sift key (tip from dave's garage) to really shutdown windows.  And that seemed to clear up any hiccup on the next boot my headphone ouput jack worked properly.
Steven_Intel
Hello 2andromeda,
I am glad to know the issue is now solved. Thank you for taking the time to share the solution.
Please be aware that the HDMI audio driver will only have an effect if the audio output goes through an HDMI connection (e.g. connected to an external monitor), it should not affect the audio jack, as it has a different driver for it.
In case you have issues with the audio jack port input, our recommendation is to contact the device manufacturer for further assistance.
Steven G.
