Hi
The screen on this laptop has recently started flickering.
Surface 3 Laptop
Windows 11 64 bit
Intel Iris Plus Graphics Driver 27.20.100.9621
I have run the Intel diagnostic software and done a clean installation of the appropriate driver, but the problem persists.
Please advise any other recommended action(s).
Jeremy
Hi
It seems to have resolved itself with a Windows update. I reinstalled the recommended Microsoft drivers (per your link) even though the issue had resolved itself.
Thanks for your help.
Jeremy
JBJS, Thank you for posting in the Intel® Communities Support.
We are sorry to hear about this issue and we will be more than glad to assist you with this matter.
In order for us to provide the most accurate assistance on this scenario, we just wanted to confirm a few details about your system:
Is this a new computer?
Was it working fine before without showing the screen flickering issue that you are describing?
The screen flickering problem, does it happen all the time or just when using some specific applications/games?
If yes, when did the issue start?
Did you make any recent hardware/software changes, besides doing a clean installation of the driver, that might cause this problem?
Any questions please let me know.
Albert R.
Hi JBJS,
Alberto_R_Intel (Moderator) posted a new reply in Graphics on 09-27-2023 06:05 AM:
Re:Surface 3 Laptop - Iris Plus Graphics - Screen Flicker
Is this a new computer? [It's about 3 years old but still in mint condition - no damage to the device whatsoever.]
Was it working fine before without showing the screen flickering issue that you are describing? [It was working normally and without problem until a few days ago. I suspect a Windows / Driver update has caused the issue.]
The screen flickering problem, does it happen all the time or just when using some specific applications/games? [It happens all the time - no specific application.]
If yes, when did the issue start? [A couple of days ago.]
Did you make any recent hardware/software changes, besides doing a clean installation of the driver, that might cause this problem? [No. Just the standard Windows update profile. Windows has updated again today but the probem persists and hasn't been resolved.]
Does the problem happen at home or in the work environment? [At home. It is only used at home (albeit for work purposes, sometimes using Citrix.]
Albert R.
JBJS, Thank you very much for providing that information and the SSU report.
Accroding to the information shown in the SSU report and as you mentioned, the graphics driver version currently installed in your computer is 27.20.100.9621.
For this scenario, it is important to mention that it is always recommneded to install the graphics driver provided by the manufacturer of the computer, since that driver was customized by them to work with your specific platform.
I looked on Microsoft's website and they have a driver package available from 9/15/2023. Please try to install that driver package in order to try to fix this problem:
https://www.microsoft.com/en-US/download/details.aspx?id=100429
If the issue remains after that, then please try a clean installation of Intel® graphics driver version 31.0.101.2125 following the instructions in the links below:
If the problem still persists after that, then try a clean installation this time of Intel® graphics driver version 31.0.101.4826:
We also recommend to get in contact with Microsoft Support in order to make sure the latest BIOS version is currently installed in your machine or to gather the instructions on how to update it:
https://support.microsoft.com/en-us
Once you get the chance, please let us know the results.
Albert R.
Hello JBJS,
I would like to know if you were able to perform the steps provided or if you had any issues along the way. Let me know if you need further assistance.
Deivid A.
Hi
Jeremy
Hi JBJS, You are very welcome, thank you very much for your response.
Perfect, excellent, it is great to know that the screen flickering problem with the laptop got fixed after installing the Windows updates. Thank you also for selecting the post as the accepted solution, we are sure it will be very helpful and useful for all the peers looking at this thread.
Any other inquiries, do not hesitate to contact us again.
Albert R.
