22671 Discussions
Switching from Intel to dGPU causes 1s freezing
inferno997
I was wondering is somebody has the same problems that I have with my Razer Blade 15 Advanced.
Spec's on the model: 2k res model with 240hz, Intel 10875h, 32gb ram, Nvidia 3080 etc.
All drivers are updated, and I am always taking a good care for my laptops with the latest system updates and all the drivers needed.
The problem is, when I am on optimus, system tends to switch between gpu's automatically and that causes 1s freezing and then it get's back to normal.
I've seen on the Intel/Nvidia forums and other that the problem persisted long before my experience and it is consistent in the other models.
Also to mention that when I disable Intel GPU in bios, the problems is no longer there (but this drains battery and when you buy a laptop for $2800, you expect everything to work.
My question are:
Is somebody solved this somehow?
Who is to blame? Nvidia/Intel or Microsoft Windows
What are your opinions on this?
David_G_Intel
Hello inferno997
Thank you for posting on the Intel️® communities. On our side we can give you suggestions for Intel products, we cannot confirm if this is a design problem or if it is common with these laptops, for that and more support you should consult directly with the manufacturer. If you want us to confirm that the system is up to date, please share with us the Intel® System Support Utility (Intel® SSU) results
David G
David_G_Intel
David G.
David_G_Intel
David G.
