Hello intel,
Our board designed with intel Alderlake-H 12500H to support thunderbolt from TCSS port2 interface. When I connect ASUS thunderbolt docking station and install NIVIDA RTX3060 Graphic card, I found that I was not able to install RTX3060 driver successfully, the windows always happen to BSOD when RTX3060 driver installed, the BSOD code shows that:
VIDEO_MEMORY_MANAGEMENT_INTERNAL (10e)
The video memory manager encountered a condition that it can't recover from. By crashing,
the video memory manager is attempting to get enough information into the minidump such that
somebody can pinpoint what lead to this condition.
Arguments:
Arg1: 0000000000000030, The subtype of the bugcheck:
Arg2: ffff888074c3cfe0
Arg3: 0000000000000000
Arg4: 0000000000000000
My windows version is WIN11 22H2.
My intel intergrated graphic driver vesion is 31.0.101.4146, and I have try to different version, but no fix the issue.
My RTX3060 driver version is 531.61, which is the newest version up to now.
For debuging, I change the windows to win10, and I found RTX can be installed sucessfully.
Beside, I used another board with intel alderlake 1260P with win11 22H2, and I found RTX3060 aslo can be installed.
How can I to fix my issue? Could you give me some advise?
链接已复制
Hello colinzhangmadigi,
Thank you for posting on the Intel️® communities. We will be more than glad to help you.
To better assist you, we would like to gather more information about your problem:
- You mentioned that this is an issue with your designed board. Are you working on a project?
- If so, what is the project about?
- Have you contacted Nvidia Support regarding this issue?
- Do you face any problems if you disable the Nvidia Card and only use the integrated Graphics adapter of your CPU?
Jean O.
We hope you are doing fine.
Best regards.
Jean O.
