I was wondering if there was an option throughout intel to adjust my texture filtering or if there is some sort of program which offers this option my GPU is a Intel(R) UHD Graphics 620, Please Help.
Thank You
danstek190, Thank you for posting in the Intel® Communities Support.
In reference to this scenario, just to confirm, when you mention "adjust the texture filtering", you mean in a game, or in a specific application, or in regular use of the computer?
Please provide the name of the application or game.
Also, for us to be able to provide the most accurate assistance on this matter, please attach the SSU report, check all the options in the report including the one that says "3rd party software logs":
Albert R.
I wanted to adjust the texture filtering in Fortnite and here is the SSU Report:
danstek190, Thank you very much for providing that information and the picture.
In order for us to get the complete SSU report, based on the information showing in the picture, please select "next" on step 2 and then save the information as a file on your computer then attach it to the thread so we can better assist you.
Albert R.
Here is the SSU Report, sorry for missing the step
Hi danstek190, No problem at all, thank you very much for providing the SSU report.
Just to confirm, did you check the "Fortnite" game menu to verify if there is an option in there to adjust the texture filtering?
Did you saw that option in the Intel® Graphics Command Center or in Windows* settings before?
In the following link, you will see some settings from the Intel® Graphics Command Center that might have the same utility as the texture filtering for you to try them:
https://www.intel.com/content/www/us/en/support/articles/000057285/graphics.html
Additionally, in the link below you will find the recommended settings validated by Intel® for the "Fortnite" game:
https://gameplay.intel.com/en-us/CPUAndGameSelected/Index/149088/641893
Based on the report, we can confirm that the Graphics driver version currently installed in your system is 27.20.100.9316, which is the Generic driver provided by Intel®"
https://downloadcenter.intel.com/download/30266/Intel-Graphics-Windows-10-DCH-Drivers
Just to let you know, we always recommend to install the graphics driver provided by the manufacturer of the computer, since that driver was customized by them to work with your specific platform. The Intel® Graphics drivers are generic, so they might or might not work with your specific platform.
I looked in ASUS's website and actually, the driver version they have available for your platform is V26.20.100.7372.
So, if you have the chance we can try a clean installation of that driver following the instructions in the link below, this will be optional, just to see if you get more options when using the driver customized by ASUS, it is not guaranteed that you will see the option to adjust the texture filtering?
Albert R.
I have re-installed the drivers but I was wondering were is the option in the Intel Graphics Command Centre or the settings but I can't seem to find it
Kind Regards
danstek190
Hi danstek190, Thank you very much for sharing those updates.
In order to see the options, please add the game or app manually or use AGS (Automatic Game Settings) to scan the system for supported apps/games profiles. Then you can manually alter Anti-Aliasing and Anisotropic Filtering options.
Albert R.
Thank you for that, I also wanted to know is there a intel version for Nvidia inspector or some program which offers those options for my GPU (Intel(R) UHD Graphics 620). If there is a software like this could you please let me know. Thanks!
Kind Regards
danstek190
Hi danstek190, You are very welcome, thank you very much for your response.
In reference to "is there a intel version for Nvidia inspector" anything related to Nvidia, you will need to check with them directly so they can further assist you with that:
https://www.nvidia.com/en-us/support/
Only the Intel® Graphics Command Center is the applications tested and validated by Intel® to work with the Intel® Processor.
Albert R.
