22649 Discussões
The Last Last of Us Part 2 and Iris Xe
PepoIRISXEl29
Novo colaborador III
17.340 Visualizações
hi, i just installed the lastest driver available ( 32.0.101.6739 ) an The Last of us part2, still has the rendering problem i stated in a discussion almost 3 weeks ago. I am using an 11th generation I5 processor, have 24 gbs of Ram, and have Intel Iris xe as intergrated graphics. The game runs on the similar spec integrated graphics amd cards.
I will share an image with this mail so you can see, it is the same that happens in the new Spider-Man 2 video game (which is also a port by Nixxes and Playstation).
Hope you can fix it, as you did with the The Last of Us part 1 on pc, which I enjoyed too much thanks to my humble setup.
I dont believe the game is too badly optimized because it´s running on handhelds pc (that runs with integrated graphics).
And to mention, i can run God of War Ragnarok, Red Dead Redemption 2 and Spiderman Remastered smoothly (for this setting is aprox in the 30fps). My laptop also runs Uncharted 4, and lastly The Last of Us Part 1. Soooo, if you guys can give the low spec faithful iris xe players a hand, we will be grateful.
The game looks exactly like this video: https://www.youtube.com/watch?v=9isFjc-gl9Y&ab_channel=VITO
i´m fully aware of a pop up message in the launcher saying the my gpu is not supported. I know the minimun specs (
Minimum (720p Low @ 30 FPS)
Processor: Intel Core i3-8100 or AMD Ryzen 3 1300X
Memory: 16 GB
Graphics: NVIDIA GeForce GTX 1650 (4GB) or AMD Radeon RX 5500 XT (4GB)
Storage: 150 GB SSD space
OS: Windows 10/11 (1909 or higher)
But this doesn´t change the fact that the problem isn´t that, the problem is within the drivers of Iris Xe and the games Nixxes Studios ports from ps4 and ps5, basing this on the fact that similar specs AMD integrated graphics (which are not in the minimum specs too) are running the game, without the rendering black and red screen problem.
For this I ask, if you can see if the DEVS can solve this driver problem so we Iris XE players can enjoy this game. There are many discussions about Spiderman 2 and the same problem on intel forums (please look into it).
I have already answer this questions:
What is the exact model of your laptop?
1. ASUS X515 EA-INTEL I5 11TH GENERATION- IRIS XE- 24 GB RAM
Have you tried using the OEM driver for testing?
2. I have
Have you used DDU to completely remove all residual drivers and installed a new one?
3. I have completely removed the old driver and install the new one, check the bios update, and the windows update.
Could you provide a screenshot of your in-game display and graphics settings?
4. All set to the minimun posible (Very Low), with IrisXee re-scalator set in balanced, fsr on, vsync on.
Which gaming platform did you use to download the game?
5. I buy it and download it from steam.
Also thanks to the community of iris xe players we came with this video Look at this https://youtu.be/_rr4mB73QWE?feature=shared.Seems
This old driver fixes the problem with the game, it might help you get into a developing and updated driver that help us ( the driver where the red and black glitch is fixed: 31.0.101.3222. Nonetheless it´s old and unstable (does not support fsr and frame generation) and the game crashes after a minute or two of gaming. Hope that this can help you guys figure out what is wrong and develop a new driver that performs well and fixes the red and black glitch in the game.)
Lastly, the game can run between 20-30 fps on high contrast mode (activated on accessibility options) which proves the point of the game running and this being definitely a driver problem.
I share multiple screenshots of my computer showing how the game looks with the bug, the settings of the game, the old driver(31.0.101.3222) that "fixes" the colors but its unstable, the high contrast mode and the Ssu of my computer.
Hope you can answer soon.
53 Respostas
rafay19
Novo colaborador I
2.280 Visualizações
BRO THEY REPLIED ME THIS CAN U TEST THE GAME ON THIS DRIVER
PepoIRISXEl29
2.270 Visualizações
No fix man, the game still looks al redish and black.
PepoIRISXEl29
2.268 Visualizações
June 5th Update: recently installed the lastest driver update 32.0.101.6876, there's no fix yet. The red rendering problem persists
PepoIRISXEl29
2.098 Visualizações
Update June 11th: using 32.0.101.6881 driver the issue still persists. Seems they don't want to fix it at all
Coke2112
Novato
2.067 Visualizações
Hola Pepo,
Thanks for insisting on this and keeping us posted.
@intel our hopes are with you guys!!!
Thanks a lot. Jorge
GuyXE
Principiante
1.613 Visualizações
still nothing? problem persists 7/3/25
PepoIRISXEl29
1.572 Visualizações
Hey man, all the Intel moderators are responding the same in any inquiry about The last of us part 2, elder ring Nightrein or spiderman 2. They won't fix it because iris xe does not meet the minimun requirements. Even though we have researched enough to show them their drivers are the ones causing this various problems. What more can i say, i have lost all hope on this.
rafay19
Novo colaborador I
1.553 Visualizações
Man I just changed my laptop to hp victus 15 ryzen 5 75H5s and rx 6550m gpu so working great with 60+ fps 1080p and **bleep** you intel for make me buy another laptop instead of fixing the drivers and not listening to your users
JBKRobin
Novo colaborador I
1.194 Visualizações
TLOU P2 is fixed on the new driver, I just heard. Is it true? Then we need to push them for Spider Man 2 and Miles Morales.
Thank you everyone. Thanks for the patience. Good job. Thanks to Intel.
Coke2112
Novato
1.174 Visualizações
Hey.. good news!!
Can anyone confirm?
Jorge
Coke2112
Novato
1.105 Visualizações
It is working!!! Updated the driver and was able to play w/ no problem for around an hour. Took a while to load initially though.
Thanks for the help @intel !! Will keep you posted hehe.
Jorge
rafay19
Novo colaborador I
1.165 Visualizações
YES THEY FIXED IT ON CHECK MY POST
Responder
