22946 Discussions
The gpu device instance has been suspended intel HD 4000
MMuru1
This is same problem as . Raising again since it was not solved
When ever I loaded the resident Evil 7 game I am getting the below error.
"d: //reengine//reengine//builder//modules//render//os//renderdevicedx11.cpp" 3796 present failed. HRESULT = 0x887a0005,The GPU device instance has been suspended. Use GetDeviceRemovedReason to determine the appropriate action"
later the getting the warning message from taskbar icon stating that
"amd driver has stopped working and successfully recovered'
I tried all the methods available in below thread but nothing helps.
https://community.amd.com/thread/180166
My System Spec:
Processor Name: Intel Core i3 3120M
RAM: 4GB DDR3
OS : Windows 10 Pro 64bit (I tried in win7,8 also same error)
GPU - AMD radeon hd 7670m (2GB) (Installed Crimson Edition 16.2.1)
Intel HD Graphics HD 4000 - Installed the latest driver (win64_153343.4425.exe)
if I disable the amd driver and run in Intel 4000 then i m getting below error
Display driver Intel HD 4000 Graphics Drivers for Windows 8(R) stopped responding and has successfully recovered on Windows 10
Note:
I have tried all the methods available in online (sfc scan, tdrdealy, intel sde,overclocking amd etc but still getting same error.
Kindly help me to proceed
Stefan3D
Try the new driver that has just been released for your GPU
MMuru1
Hi Stefan,
Thanks for the update. I have uninstalled all display drivers , restarted and then installed the mentioned driver. It was successfully installed but still getting same error.(mentioned driver was released on mid of 2016)
Attached the screenshot of error.
Can you please guide me the next step?
Stefan3D
Since the error message "d: //reengine//reengine//builder//modules//render//os//renderdevicedx11.cpp"... pinpoints an issue in the source code of the game i would try to contact its developer.
http://www.capcom-unity.com/go/capcom/support http://www.capcom-unity.com/go/capcom/support
http://www.capcom-unity.com/resident_evil/go/forum/view/7391/253059/resident-evil-7 http://www.capcom-unity.com/resident_evil/go/forum/view/7391/253059/resident-evil-7
MMuru1
Thanks Stefan. Waiting for your response to proceed.
Hello mvpmurali,
As Stefan3D mentioned above, I suggest you to contact the game developers for an update or patch since this is an error coming directly from the game.
Perhaps you can try here:
https://steamcommunity.com/app/418370/discussions/ https://steamcommunity.com/app/418370/discussions/
NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Ivan U.
