23740 Discussions
UHD Graphics 620
prstojevicpetar
Hi, in the morning I updated my driver and restarted, but I couldn't even get to the login screen to log in, it was black with no cursor, I heard the sound so it must be the graphics driver. I went to safe mode and changed the driver to "Microsoft basic display adapter" and then it worked, I tried to update with different versions of the driver but none worked. Please help me, also I cannot do a clean installation. (Intel core i3-1115G4, Tiger lake)
Jean_Intel
Hello prstojevicpetar,
Thanks for posting on the Intel Communities. We are more than glad to help you with the issue with your graphics adapter.
There are two different types of drivers, generics provided by Intel and Equipment Manufacturer drivers, that are customized to work with each specific system. The best thing to do is to use the drivers provided by the system manufacturer (OEM) or through Windows Update to eliminate the potential impact caused by loading non-custom drivers.
To better understand your issue, please provide us with the following:
  • This issue started as soon as you installed the latest graphics driver.
  • Does the issue occur if you navigate through the BIOS menu?
  • In case you can try using another display/monitor and video output.
  • Create a report using the Intel®️ System Support Utility (Intel®️ SSU)
    • Download the Intel SSU
    • Open the application and click on "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
    • To save your scan: click on "Next"; then "Save."
Jean O.
Jean_Intel
We hope you are doing fine.
Jean O.
Jean_Intel
Best regards.
Jean O.
