Hi all. I want buy i5-10400 with UHD 630. Can display 3400x1440 in 100HZ? I cant find it anywhere. Thank you.
By my reconing, this processor, if using DisplayPort 1.2 output, should be able to support this monitor at up to 120Hz. If there is any signal loss, this might knock the connection down to 85Hz. A similar result will be achievable if using a motherboard with a LSPcon IC to convert from Displayport 1.2 to HDMI 2.0. If using the processor's native HDMI 1.4 output, best result will be 50Hz/60Hz.
Hope this helps,
Hope this helps,
