23269 Discussions
Unable to get audio when connected to HDTV via Displayport/HDMI active adapter
LN2
I wanted to watch Netflix on my HDTV via my computer so I used an active Displayport HDMI adapter to connect. This is the adapter I'm using:
https://www.visiontek.com/computer-accessories/cables/visiontek-displayport-to-hdmi-adapter-detail.html https://www.visiontek.com/computer-accessories/cables/visiontek-displayport-to-hdmi-adapter-detail.html
The video is fine but the audio comes from the computer not the TV.
The TV doesn't appear under audio playback devices even when I show disabled or disconnected devices so I can't switch it over.
The TV appears as a Generic PnP monitor in Device Manager.
Spec: Dell Optitplex 780 SFF
Windows 7
Intel Q45/43
GMA 4500
driver 8.15.10.3202
Just thinking that either the integrated video doesn't send HDMI audio over the Displayport, I need a different video driver, or I am using the wrong adapter.
Any help appreciated.
Thanks a bunch!
LN2
More info:
32 bit Windows 7
HDTV: Sharp LC-42SB45UT
Silvia_L_Intel1
Hello Ghostsafe, I'm sorry for the inconvenience that you have faced with your system.
We always recommend using straight connections from the board to the display.
You can also try installing the latest graphics drivers available. From our side the latest drivers are the following https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22165 Intel® Download Center you may want to check with Dell if they have a newest version.
In addition to that, you could also try another adapter.
JStew12
I also have a Dell Optiplex 780 and have the same issue. I just downloaded the Intel driver update utility and brought everything up to date. Updated the Dell BIOS to latest revison, and latest Windows updates. Can you confirm wheter or not the Intel Q45/43 express supports audio over the display port? Based on the research i've done from displayport.org they say not all display ports have that feature of supporting both audio and video. I've used different TVs and different Display Port to HDMI adapters. Everything works fine on my laptop when testing and the TV shows as an audio device under the sound settings in control panel...but on the Optiplex 780 the TV doesn't show up at all.
See this link:
http://www.displayport.org/wp-content/uploads/2011/10/DP-Audio-User-Guide-v1.pdf http://www.displayport.org/wp-content/uploads/2011/10/DP-Audio-User-Guide-v1.pdf
IUman
As sylvia_intel has mention, we always recommend using straight connections from the board to the display.
This is because these devices need to modify and transfer the signal coming from the system to display it in another connector type and during this process the system can be affected and therefore not displaying the information or sending the signals as it should.
