Hi, I am using a DELL Inspiron 3020 with an Intel UHD 770 and a LG ultrawide monitor (29WP500). I had looked through different forums and I could not find a way to display 21:9 graphics on the monitor. I have tried connecting the monitor with another laptop computer and everything worked fine. I have attached the SSU report and the Driver report. It would be great if the problem could be solved. Thank you.
Hello, @Justin73
Thank you for your contribution to this, Mr. Scott.
In case there are no adapters and it's a straight connection, as per your Laptop's model manual, your HDMI port resolution is limited to 1920x1200 (page 15).
As your System Manufacturer only allows a max of 1920 x 1200 via HDMI, you might not be able to go further through this port. Besides this resolution of 1920x1200 is not within the EDID of the monitor as per the IGCC report, which is one of the reasons why you are only reaching 1600 x 900 (and this resolution is within the EDID of this monitor as per the IGCC report).
I noticed that this monitor doesn't have a DisplayPort option and Intel does not recommend using any kind of adapters and can not guarantee 3rd party products/adapters will work as expected: Using Video Cable Adapters, Splitters, and/or Docking Stations in Computers not Manufactured by Intel
In summary, this seems to be a System Manufacturer limitation, so we recommend you contact them for further assistance.
Jocelyn M.
Hello, @Justin73
I understand that you are having issues with your resolution settings, I will do my best to assist you here.
Please try updating your graphics driver to the System Manufacturer's driver 31.0.101.4502. If it doesn't work, update the driver to the latest Intel graphics driver version 31.0.101.4972. Check the notes below before doing this step:
Note #1: Make sure to check you have all the Windows updates before doing the driver installation. Also, make sure to do this step disconnected from the internet (wi-fi or wired connection) since Microsoft updates drivers automatically and prevents doing the clean installation successfully.
Note #2: Since this is a laptop, we recommend using the driver software provided by your System Manufacturer to avoid potential installation incompatibilities. Intel supplies generic versions of Graphics Drivers for general purposes. Computer manufacturers might have changed the features, incorporated customizations, or made other changes to the graphics driver software or software packaging.
Note #3: In case you had to use the Intel driver, please find the instructions on how to install the driver in this article: How to Install an Intel® Graphics Driver in Windows® 10 & Windows 11*.
Jocelyn M.
Hi Jocelyn, thank you for your help. I have followed your instructions and updated the graphics driver. However, the problem persists. There is still not an option for 2560x1140 in the graphics tab.
Hello, @Justin73
Please try a Clean installation of your graphics drivers, using the System Manufacturer's driver 31.0.101.4502. If it doesn't work, try this step with the latest Intel graphics driver version 31.0.101.4972.
If the issue persists, please attach a new SSU report so we can investigate further this issue.
Jocelyn M.
Hello, @Justin73
Thank you for the reports provided.
In that case, let me do some research about this issue. As soon as I have updates or recommendations, I will let you know.
Jocelyn M.
Hello, @Justin73
Thank you for your time.
Can you please confirm the following?
- Are you using a straight connection from the monitor to your laptop (e.g. HDMI to HDMI)? Or are you using adapters?
- What is the model of the monitor? Please specify.
Jocelyn M.
Monitor was described in original post: LG ultrawide monitor (29WP500). It has HDMI inputs.
Specs for Inspiron 3020 indicate both HDMI (1.4b) and DisplayPort (1.4) outputs.
There is something in specs that might explain the problem. It says: "NOTE: HDMI port resolution is up to 1920 x 1200".
I wonder if the answer here is to use DP-to-HDMI adapter.
Hope this helps,
..S
Oh, and according to the specs for the monitor, it is only 2560x1080, not 2560x1140.
Hello, @Justin73
Jocelyn M.
Thank you @Jocelyn_Intel and @n_scott_pearson for taking your time helping me out, I will look into it with Dell.
Hello, @Justin73
Thank you for your reply.
I am glad I could assist you until now and I hope you can get further assistance for this issue soon with them.
This thread will no longer be monitored, but if you need assistance with other matters, feel free to contact us and submit a new post.
Have a nice day.
Jocelyn M.
Hola, @Jocelyn_Intel @Justin73 @n_scott_pearson
Tengo el mismo problema con una computadora Lenovo IdeaPad Slim 5 16IRL8 - Serie tipo 82XF. y con un monitor LG ultrawide (29WP500) ya tengo los controladores actualizados y Intel(R) UHD Graphics con la versión del controlador 31.0.101.5333, ¿sabes cómo puedo hacer que tome la resolución recomendada, que es 2560 x 1080?
Muchas gracias
![](/skins/images/C4F7392A5C68ACA60290C9576F107044/responsive_peak/images/icon_anonymous_message.png)
