23776 Discussions
Updating XE Drivers
Len99
I have the Intel Driver Support Assistant installed. When I'm advised of a driver update I use the assistant to download and install. Every time I've done this the update fails and I'm then invited to install via a reboot - this normally works.
However, once the driver is installed it removes/corrupts my Realtek sound drivers and I get a message saying 'no playback devices'. I then need to re-install Realtek.
Am I doing something wrong, is there a setting I need to change, or is it a bug?
I'm using Windows 10 pro which is up-to-date.
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[Windows 11 is the new Vista]
Len99
Thanks for your speedy response. SSU text file attached.
Len
David_G_Intel
Hello Len99
Thank you for posting on the Intel️® communities. From the report provided we noticed the following:
You can find steps for the manual installation in our article:
If the issue persists, please try a different driver from the same download website and let us know.
David G
David_G_Intel
David G.
Len99
Hi David,
I checked out the BIOS using Asus EZ Update. It shows I have v0707 and says there is no update.
I followed the manual driver update route and this seems more robust, Additionally, I'm hoping it's also solved my other issue and stopped Windows Update over-writing with an out-of-date version.
Many thanks,
Len
David_G_Intel
We're glad to know the information helped, hopefully it will help other community members. As per OEM website, the latest BIOS is 1007
You can confirm with Asus which one is recommended. To stop the automatic driver (Windows*) updates you can check with Microsoft directly. Let us know if you have any questions.
David G
David_G_Intel
David G.
