22649 Discussions
Upgrade Intel® Graphics Driver 30.0.101.1660 causes start up problems laptop
HBO70
Last update; Intel® Graphics Driver 30.0.101.1660 cause start-up problems laptop. Windows 11, 11th gen. Both screens stay black.  Only hard reset helps with second screen disconnected. Connecting second screen after start-up is no problem. Tried reinstall, deleted drivers, upgrade monitor (sams Odysee 27") replayed cable, updated windows 11. Nothing helps. Anyone with a helpfull tip?
HBO70
Jean_Intel
Hello HBO70,
To have a better understanding of your issue, please provide me with the following:
  • You mentioned that you reinstalled and deleted drivers. Does it mean that the issue persists after you tried reinstalling the driver 30.0.101.1660?
  • Was there any other hardware or software change besides the driver update?
  • When you do a hard reset as a workaround for your issue, do you experience any other type of display errors?
  • Create a report using the Intel®️ System Support Utility (Intel®️ SSU)
Jean O.
HBO70
Hello Jean.
Yes, Laptopscreen is black en 2nd screen goes to sleep
Apple, icloud, etc.
No
Create a report using the Intel System Support Utility (Intel SSU)
I already send a report. I wil send both old and new
When i do a restart FireFox won’t start. “there is already a version running, you need to close old to proceed” probably because of hard reset
HBO70
Scan also sent is first message
HBO70
Starting INTEL Computer improvent programm, microsoft error .NET Framework
Zie het einde van dit bericht voor meer informatie over het aanroepen
van JIT-foutopsporing (Just In Time) in plaats van dit dialoogvenster.
************** Tekst van uitzondering **************
System.ArgumentException: De bestandsindeling is niet geldig.
bij System.Windows.Forms.RichTextBox.StreamIn(Stream data, Int32 flags)
bij System.Windows.Forms.RichTextBox.StreamIn(String str, Int32 flags)
bij System.Windows.Forms.RichTextBox.set_Rtf(String value)
bij System.Windows.Forms.RichTextBox.OnHandleCreated(EventArgs e)
bij System.Windows.Forms.Control.WmCreate(Message& m)
bij System.Windows.Forms.Control.WndProc(Message& m)
bij System.Windows.Forms.RichTextBox.WndProc(Message& m)
bij System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Geladen assembly's **************
mscorlib
Assembly-versie: 4.0.0.0
Win32-versie: 4.8.4470.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
SurConsent
Assembly-versie: 2.4.0.8840
Win32-versie: 2.4.0.08840
CodeBase: file:///C:/Program%20Files/Intel/SUR/ICIP/SurConsent.exe
Win32-versie: 4.8.4488.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32-versie: 4.8.4395.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Config
Win32-versie:
CodeBase: file:///C:/Program%20Files/Intel/SUR/ICIP/Config.DLL
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
mscorlib.resources
Win32-versie: 4.8.4161.0 built by: NET48REL1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_nl_b77a5c561934e089/mscorlib.resources.dll
System.Configuration
Win32-versie: 4.8.4341.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Windows.Forms.resources
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_nl_b77a5c561934e089/System.Windows.Forms.resources.dll
************** JIT-foutopsporing **************
Als u JIT-foutopsporing wilt inschakelen, moet in het configuratiebestand voor deze
toepassing of computer (machine.config) de waarde
jitDebugging in het gedeelte system.windows.forms zijn ingesteld.
De toepassing moet ook zijn gecompileerd terwijl foutopsporing
was ingeschakeld.
Bijvoorbeeld:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
Wanneer JIT-foutopsporing is ingeschakeld, worden onverwerkte uitzonderingen
naar het JIT-foutopsporingsprogramma gestuurd dat op de computer is geregistreerd
en worden niet door dit dialoogvenster verwerkt.
Jean_Intel
Hello HBO70,
Thanks for your response. The information provided has been helpful.
I was looking for your laptop model provided by the Intel® SSU; however, I didn't find any information related to the product. The report shows that the system is TIMI TM2029-31473. Can you provide me with the website of the system manufacturer?
Since you mentioned that the issue persists after uninstalling the driver, it doesn't seem that the problem is related to this specific driver version. I want to suggest performing a clean instalation for our latest driver (30.0.101.1660).
 1. Download the latest DCH drivers and save them on the computer: (https://www.intel.com/content/www/us/en/download/19344/intel-graphics-windows-dch-drivers.html)
2. Disconnect from the Internet so no new drivers are automatically installed by Windows Update.
3. Uninstall the driver and the Intel Graphics Command Center and driver from Apps and Features.
4. Restart the computer.
5. Confirm in Device Manager > Video Adapters that the controller is listed as 'Microsoft Basic Display Adapter' > if not, repeat steps 2 through 4.
6. If the adapter continues to be listed as ‘Intel HD Graphics’ or similar, and no other Intel Graphics driver is listed under 'Apps and Features' for removal, then it means Windows has switched to a previously installed Legacy driver. At this point we can remove Legacy drivers from Device Manager:
1. Right-click on 'Intel HD Graphics' or similar, and select 'Uninstall Device'
2. In the pop-up window make sure 'Delete the driver software for this device' is checked.
3. Click on 'Uninstall'.
4. Restart. (Repeat steps 6.1.1 through 6.1.4 until the device gets listed as 'Microsoft Basic Display Adapter')
7. Install the DCH drivers that were downloaded in step 1 Restart the computer.
Reconnect to the Internet.
Jean O.
Jean_Intel
Hello HBO70,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello HBO70,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
