23769 Discussions
Intel UHD Graphics 730 has problem with AutoCAD 2016
VincentLeung
I have a computer with Intel UHD Graphics 730. After installing the driver, the AutoCAD 2016 will crash. However, if using the driver of Microsoft Basic Display Adapter, there will no problem.
Is there any solution?
n_scott_pearson
There's certainly going to be no resolution of any kind when you don't provide enough information!
What specific processor are we talking about?
How much memory does the system have (specifics of DIMMs - including part numbers - would be helpful)?
What OS (including version and update level) are you using?
What version of the UHD Graphics driver are you running?
Has AutoCAD ever worked on this PC?
Most of this could be automatically established if you provided a report from the Intel SSU utility. Please download and run the Intel System Support Utility for Windows. When you start the tool, select Everything and then click on Scan. Once it completes the scan, click on Next and then Save. Pick a name for the report (text) file to be created and click on Save to create it. You can then close the app. Finally, open a response post here and then, using the Drag and drop here or browse files to attach dialog (below the edit box for the body of your response post), upload and attach this text file to the response post.
