23833 Discussions
Upgrading Intel video card
Xlord
Am I able to upgrade Intel Core i3 video card to a i5 one? If yes, how?
AlHill
Not unless you replace your processor, which may not be possible.
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[Waiting for Windows 12]
n_scott_pearson
For information regarding what processor(s) your platform supports, you will need to consult the documentation provided by your motherboard/system manufacturer. If it doesn't seem to be covered in their online documentation, you will always contact their support organization.
Hope this helps,
