22747 Discussions
VGA light RED with Arc a770
BakChoi
I just finished building my PC, turned it on, and the Motherboard's VGA light is solid red.
My Motherboard is B660 AORUS MASTER DDR4 (rev. 1.0)
https://www.gigabyte.com/Motherboard/B660-AORUS-MASTER-DDR4-rev-10#kf
my GPU is Intel Arc A770 Limited Edition 16GB.
Does anyone else have something similar happen to them? Could my GPU be defective?
BakChoi
Thanks for your help Scott. I took everything apart, and rebuild the thing and it worked after... Maybe something wasn't plug in right the first time around. Thanks for your help.
n_scott_pearson
Are graphics working? If it's just a LED issue, I would contact the mobo vendor. If it's no display at all, then either system build issue or bad GFX card. How big a PSU are you using? Have you tried removing the card and using iGFX?
BakChoi
I am not sure if the graphic card is working or not, to be honest. I see LED coming up, the fan spins a little then stops after starting up.
I got no display at all, my PSU is Deepcool PQ850M Gold. My CPU is Intel 12700KF, so it doesn't come with an integrated graphic card.
n_scott_pearson
How are you connecting the monitor? Have you tried all ports on the GFX card?
BakChoi
