22770 Discussions
VIDEO_DGXKRNL FATAL ERROR 113
RMoni
hi, i just got a dell inspiton 5537 with windows 8 .. and everything was working fine.. however after i upgrade to windows 8.1 i started having some issues.. i each time i start the pc .. the dell logo appear twice and the laptop takes a lot of time to boot.. also if 1 put it on sleep when i press the wake up button. its restarts..
i have run a blue screen screen viewer
is says that its a directx graphics problem.. but i dont understand it. here is the link to the minidump file:
https://skydrive.live.com/redir?resid=5D688E1FA20112E6!2512&authkey=!AJ39Kpa8lo_R7Bc&ithint=file%2c.rar minidumps
anyone know how to fix this?
Thanks..
Kevin_M_Intel
Hi Tarounen,
I am sorry to hear you are having issues with the computer but let me help you with it.
Checking the information and the computer specifications in the web, it seems this computer may be running with the 4th generation processor.
As part of the troubleshooting steps, I recommend you updating the bios in your system and then uninstalling the graphics driver from device manager and download the latest one at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23405&lang=eng&OSVersion=Windows%208.1%2C%2064-bit*&DownloadType=%0A%09%09%09%09%09%09%09Drivers%0A%09%09%09%09%09%09
It is important to mention that the manufacture always provides the drivers for the original operating system but also, they can set software limitations. Most of the times when changing the operating system in an OEM system for a retail version, there are some features on the system that may not work properly so I recommend you contacting the computer manufacture to confirm if the unit can handle win 8.1 without any problem.
Kevin_M_Intel
Hi Tarounen,
RMoni
thanks a lot.. the sleep seems to be working since i change the driver.. i have test the boot time yet.. but i think it should be working
RRast1
i guess the above link isn't working...please can you provide me with a valid link..since I'm facing the same problem..although I'm dual-booting (I hope it doesn't have any effect on this?)
Also do I even have to update the amd graphics drivers?
Kevin_M_Intel
HAli61
i tried it but my laptop is still giving same error plz tell me what to do ?
Kevin_M_Intel
If you have done the steps mentioned in the links above, I recommend you contacting the Computer Manufacture for them to check the unit and replace it if necessary.
AStoj2
Hi, I am having the exact same problem, but this link doesn't work anymore, can you please provide another one. I have Dell Inspiron 17 (3737, Mid 2013). Thank you.
Kevin_M_Intel
Try installing the latest driver from our side. Here it can be downloaded:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24245&lang=eng&ProdId=3720 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24245&lang=eng&ProdId=3720
If you have problems during the installation, try the steps here:
/docs/DOC-22542 https://communities.intel.com/docs/DOC-22542
If issue persists, you may need to contact Dell to get their special driver for your computer.
Kevin M
