23105 Discussions
Video display will not display Dell Precision 5130 -
SScot10
I have a new Dell precision 5130 with factory built-in AMD Firepro W5130M, and INTEL HD 530 display adapters. I am attempting to get a video stream from a Milestone camera feed but images will not display. Drivers for both adapters are up-to-date as is the Milestone software.
Help
Hello, sr77318:
Could you please provide me with the name of the Milestone software you are using? I would also need the report from the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Download Intel® System Support Utility, please download the utility and attach that report.
Amy.
SScot10
Thank You for getting back with me. Attached is the log file from the support utility scan.
I am currently running the latest version of Milestone Xprotect client for a 64bit machine which is version 10.1. I have also attempted to downgrade to earlier versions with no luck.
The machine is bundled with an Intel card and a AMD card for some reason. I have tried every driver update possible with no success.
When I open Milestone, all preforms as expected, I just get no video display. I am at a loss….
Thanks for your help!
Thank you for the report.
You can try updating your graphics drivers to the latest, see the links below; however, the issue with the video stream could be related to the software configuration. Since I am not familiar with this software I believe you should try contacting http://forum.milestonesys.com/ Milestone - Milestone Systems - Forums for XProtect® Software first, if they confirm that the issue is in fact a graphics issue we can continue from there.
Intel® HD Graphics 530
https://downloadcenter.intel.com/download/26099/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345 Download Intel® Beta Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.40].
Workstation Graphics Drivers
http://support.amd.com/en-us/kb-articles/pages/workstation-graphics-drivers.aspx Workstation Graphics Drivers
Amy.
Hello, /thread/105725 sr77318:
I am following up your case; were you able to contact http://forum.milestonesys.com/ Milestone - Milestone Systems - Forums for XProtect® Software?
Amy.
SScot10
They were of no assistance either.....The BETA driver you suggested will not install in a DELL laptop as the DELL video driver is proprietary to Dell and Intel. All the latest DELL drivers are installed....
/thread/105725 sr77318, I am sorry to hear that, let me see what I can do from my end. In the meantime, please try this method in order to ensure the installation of the driver; http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html How to Manually Install an Intel® Graphics Driver in Windows® 10 &..., let me know how it goes.
SScot10
Manually deleted Dell driver and manually installed the BETA. Showing driver version 20.19.15.4474 under graphic properties, with issue date of June 13th, 2016.
Same result in the Milestone program....no video displayed...
SScot10
Also tried the latest BETA driver 20.19.15.4501 dated August 11th. Still no luck
Thank you for trying that driver.
I would need more information in order to address this matter, so please provide me with the DxDiag report. See the instructions here http://www.isunshare.com/windows-10/4-ways-to-open-directx-diagnostic-tool-in-windows-10.html 4 Ways to Open DirectX Diagnostic Tool in Windows 10, once done save the information and attach it.
The content on the above site is not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel for the merchants or services offered there.
Amy.
SScot10
Here you go Amy,
Thanks for the continued help!
Sure and thank your for the report.
Now, let me review the case and as soon as I have more information on to proceed, I will let you know.
Amy.
I noticed from your report that the version installed is .4483. Did you downgraded the version .4501 to that version?
Could you please provided me with the name of the Milestone software version? I know you mentioned that you are using the Milestone Xprotect client, but I cannot find it here https://www.milestonesys.com/support/download-software/?type=11&lang=27 Milestone Systems - Download our video Management Software. If I am wrong; could you please clarify that? I would also like to gather more information of the camera you have, please let me know the model and how you are connecting it to your computer.
In post # 5, I quote; "They were of no assistance either.....". What did they say in regard to your issue? Was there any troubleshooting involved? Please, feel free to add all the details you can.
Amy.
SScot10
.4483 is the latest offered by Dell via support website, I attempted .4501 from your support site using the driver update utility you provide, and was given an error message indicating the driver is not compatible with the Dell PC
See Attached
Use this method for the installation; http://www.intel.com/content/www/us/en/support/graphics-drivers/000005474.html How to Manually Install a Graphics Driver in Windows 7*. This method will ensure the installation of our driver.
/thread/105725 sr77318, I am missing some information from the last post; could please check post # 12 and reply to that?
Thank you.
Amy.
SScot10
I then completely wiped out the .4483 driver, rebooted and did a manual install on the .4501.....
The verdict is.....
TaDa! It now seems to be working!!!!
Must have been a bug in the Dell driver
Thank You Amy!
SScot10
As another reply to my # 15, for those out in cyberland, Windows update will try to force you back to .4483. I simply hid the update and all is harmonious in pc land now
/thread/105725 sr77318, good to hear! So, just to confirm; you were able to install the driver, but did it solve the main issue?
Amy.
SScot10
Awesome!
If you need further assistance let us know.
Amy.
