23807 Discussions
Videocards
KirMak
Hello, i'm choosing a videocard and I don't really understand the difference between
1) Intel ARC A770 16GB Limited Edition
2) ASRock Intel Arc A770 Phantom Gaming 16GB OC
3) Acer Predator BiFrost ARC A770 OC 16 GB GDDR6
which one is better to take? I need it for 2 things - gaming and AI. So there is a second question, is there a library like cuda for nvidia? Thanks for responding
Hugo_Intel
Hello KirMak
Thank you for posting on the Intel Communities. We appreciate your interest in our Intel® Arc™ A770 GPU and will be happy to answer your questions.
In regard to the difference between the different GPUs, the main difference between assemblers is the frequency since they will usually increase the clock frequencies to a higher value than the Limited Edition GPU, due to this the other main difference will be the thermal design (fan and heatsink) they install on the GPU. We advised that you check with each of our partners for detailed information but you can find the specifications in the following links:
Intel® Arc™ A770  LE Graphics
https://www.intel.com/content/www/us/en/products/sku/229151/intel-arc-a770-graphics-16gb/specifications.html
https://pg.asrock.com/Graphics-Card/Intel/Intel%20Arc%20A770%20Phantom%20Gaming%2016GB%20OC/
PREDATOR BIFROST Intel® Arc™ A770 OC
https://www.acer.com/us-en/predator/graphics-cards/predator-bifrost-intel-arc-a770-oc
Answering your second question, in case you are going to use AI workloads our GPUs are built with Intel® Xe Matrix Extensions (Intel® XMX) Engines which greatly improve the performance of any type of AI generation. Instead of CUDA cores for Nvidia, our graphics cards use Xe cores for rendering. You can find detailed information about our architecture in the following link:
Xe-HPG Microarchitecture
Hug O.
Hugo_Intel
Hello KirMak
We shared information related to the difference between the GPU from other assemblers as well as information related to our AI technologies and related to the graphics architecture in our alchemist GPUs. Let us know if you have any other questions related to this topic.
Hugo O.
Hugo_Intel
Hello KirMak
We hope you found value in the information we shared in regard to the Arc GPU differences between manufacturers as well as the information related to AI cores in our Intel Arc A-Series GPUs.
Since there are no more questions we will be closing this thread, but feel free to open a new topic if you need further assistance.
Hugo O.
