I found a probably a bug with the Intel graphics driver,
I could copy the same problem with different NUC type of devices,
including Bay Trail, Cherry Trail and Braswell platforms,
they all have the same problem, when the problem appears, the screen goes black, leaving only the mouse cursor on screen,
if you are lucky enough, you could blind-click into the system, then display could come back but it would be the extended desktop screen,
the primary screen is gone.
- Display OK at the beginning
- Unplug HDMI cable from the system
- Now put system to sleep
- Plug HDMI cable back to the system (while it's still sleeping)
- Now, wake up the system
- Problem appears by 100% – a non-exist virtual display – "Generic Non-PnP Monitor" device now appears in device manager/servlet/JiveServlet/showImage/2-434323-308688/nonpnp.jpg
- Video output mode being changed to extended desktop automatically: Virtual display + the external display, and virtual display takes over the display priority/servlet/JiveServlet/showImage/2-434323-308689/virtual.jpg
- To recover, unplug HDMI and plug it back, display back to normal (Virtual Display – Generic Non-PnP Monitor disappeared), no more extended desktop, and primary display go back to the external display as it should
- /servlet/JiveServlet/showImage/2-434323-308690/novirtual.jpg
- Tags:
- Drivers
Quite obvious that the display output is messed up.
I could copy the same problem on these devices:
1.) Intel Compute Stick STK1AW32SC (Cherrytrail Z8300)
2.) Asrock Beebox N3150-NUC (Braswell N3150)
3.) MINIX NGC-1 (Braswell N3150)
All of them are running the latest Windows 10 Anniversary edition + their latest graphics drivers installed.
"if you are lucky enough, you could blind-click into the system, then display could come back but it would be the extended desktop screen,
the primary screen is gone."
If the system has no password, hitting ENTER could go inside the wrong extended screen.
Hello kenofstephen ,
Thank you for joining the Intel community.
Would you please fill out the information at the following link to better assist you.
/thread/77761 https://communities.intel.com/thread/77761
Please don't forget the SSU file the DxDiag and the DispDiag, also I will appreciate if you can attach the graphics report with the driver version that you have the issue.
You can follow the steps to get the Report for Intel® Graphics Drivers here:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005848.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005848.html
Ivan.
Hi Ivan,
I shall provide what you asked for as soon as I have time to do so.
Thank you enofstephen, meanwhile I recommend trying the new driver that Intel has released, you can download it here:
https://downloadcenter.intel.com/download/26404/Intel-Graphics-Driver-15-45-?product=88355 https://downloadcenter.intel.com/download/26404/Intel-Graphics-Driver-15-45-?product=88355
I suggest you to uninstall the old driver first and then install the new one.
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005598.html Uninstalling the Intel® Graphics Driver and Intel® Display HDMI/Audio Driver
Ivan.
Sadly the driver is not suitable for the devices I mentioned.
Thank you kenofstephen , once you post the information we can continue from there.
Best wishes,
Ivan.
Hello ,
I'm following on this post to ask you if your issue has been resolved or if you need further assistance.
Ivan.
Hi Ivan,
I found a patch on the Internet that disable the virtual display function of the Intel driver which temporarily fixed the problem,
but it shouldn't be fixed this way because the virtual display capability is lost after applying the patch.
Here is the patch:
; ForceVirtualDisplay
; 1-Enable Virtual Display 0-Disable Virtual Display
cmd /c reg ADD "HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4d36e968-e325-11ce-bfc1-08002be10318}\0000" /v ForceVirtualDisplay /t REG_DWORD /d 0 /f
cmd /c reg ADD "HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4d36e968-e325-11ce-bfc1-08002be10318}\0001" /v ForceVirtualDisplay /t REG_DWORD /d 0 /f
cmd /c reg ADD "HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4d36e968-e325-11ce-bfc1-08002be10318}\0002" /v ForceVirtualDisplay /t REG_DWORD /d 0 /f
Thanks for the information kenofstephen, if you could post the information that I requested above it will be great so we can further investigate on this issue.
Please fill out the information at the following link to better assist you.
Ivan.
I'm having this exact problem with my laptop. Where did you find the patch?
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Video output jumped to extended desktop mode by itself if HDMI is unplugged before sleep and plug back before wake up
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): X
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
MINIX NGC-1
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
NO
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)EFP = External Flat Panel (Monitor you plug in)<td style="padding: 0 5.4pt; border-top: none; border-right: 1pt solid windowtext; border-bottom: 1pt solid windowtext; border-left: none; font-style: inheri...
Hello kenofstephen,
Just to make sure, did you try the Intel® generic driver? You can download it here:
https://downloadcenter.intel.com/download/25176/Intel-HD-Graphics-Production-Driver-for-Windows-10-64-bit-N-Series-?product=87258 https://downloadcenter.intel.com/download/25176/Intel-HD-Graphics-Production-Driver-for-Windows-10-64-bit-N-Series-?product=87258
Before installing this driver, I suggest you to uninstall the old driver restart your system and install the generic driver manually.
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Manually Install an Intel® Graphics Driver in Windows® 10 and Windows 8*/8.1*
Please let me know how it goes.
Ivan.
I was using that driver before, same problem, please note.
The problem is not hardware dependent,
I am having the same issue on 3 different platforms of different brands.
They have one thing in common - they are all mini PCs without internal display.
I have tried to replicate this issue but I don't see the same behavior, when this happens does it cause any error in your system unable to work with it?
Ivan.
Interesting, I can copy on 3 different platfoms of different brands with the same method and you say you can't.
May I know how do you copy? Did you exactly follow these steps?
- Display OK at the beginning - NO PROBLEM at this point
- Unplug HDMI cable from the system - System is still running
- Now put system to sleep by pressing the power button - System goes into sleep without HDMI cable attached
- Now, wake up the system - You will then see the problem
Your China office can copy this problem, I don't know why you can't.
