LOL无法初始化图形设备_图拉丁吧_百度贴吧 (baidu.com)
腾讯服务器的英雄联盟玩家出现了非常严重的问题,我们急需帮助,很多人在使用英特尔显卡的时候出现了类似问题并且无法解决。
我们无法进入游戏,提示无法初始化图形设备,我们无法找到解决方法。
这个问题是今年6月开始的,我们急需开发人员发布补丁帮助我们。
谢谢!
Hello Anonymous
请放心,我只能用英语为您提供支持。我使用网络翻译工具来翻译此回复,因此可能存在一些翻译不准确的情况。
Thank you for posting on the Intel Communities. I am sorry you are experiencing crashes when trying to play League of Legends.
This issue has been previously reported and we were closely working with the developer to come up with a fix. The problem was supposed to be fixed in the latest version of the game. So as a first approach, please test and make sure that you are using the latest version/patch for the game.
If the issue persists, please share with us the following information:
- Is Resizable BAR enabled on your system?
- Share a screenshot of the in-game graphics settings or API the game is using in English if possible.
- Share a screenshot of the game version that you are using.
- Create a log file with the Intel® System Support Utility and attach it to your response to get more information on the hardware configuration.
Hugo O.
我帮你翻译一下Intel的回复吧
此问题先前已经有用户报告了,我们正与游戏开发商密切合作制作解决方案。该问题应该在最新版本的游戏中得到解决(译者:不知道国服更新了没有?)。所以请先检查一下游戏版本,确认是否为最新。
如果问题持续,请告知我们以下相关信息:
- Resizable BAR是否启用?
- 游戏内画面设置如何(请截图)?使用何API(诸如DX9,DX11,Vulkan)?如可以的话请尽量使用英语。
- 游戏版本为何(请截图)?
- 使用 Intel® System Support Utility 获取一份诊断文件并附在回复中,我们希望了解你的其他硬件配置。
祝好,
Hugo O.
英特尔客户支持工程师
Hello Anonymous
I hope you are doing fine.
Hugo O.
Hello Anonymous
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
