22649 Discussions
Webcam showing name as OV02C10. Any way to change or plan to update?
Ntardif
We have a webcam on our staff PCs using the Intel driver for the camera sensor. This is is causing it to show "OV02C10" as its name inside of applications which is not user friendly.
Is there a way to change that name or any plans to update the driver to give it a friendly name?
Computers are Dell Latitude 7440.
Dell does not provide their own driver and the default driver comes from Intel.
https://www.catalog.update.microsoft.com/Search.aspx?q=camera+sensor+ov02c10
AlHill
Not an Intel product as far as I know.   More likely, you should be checking here:
https://www.ovt.com/products/ov02c/
n_scott_pearson
Yes, it's a camera supported by Intel AVStream Camera driver. Mine identifies itself as OV9734.
Jocelyn_Intel
Hello, @Ntardif
Thank you for posting on the Intel® communities. I will do my best to assist you here.
In order to do some research on this, please provide us with a screenshot of where are you seeing the device name "OV02C10", and run the following utility and attach the report to have more information about your system:
Intel® System Support Utility for Windows.
Note: Make sure to mark the box that says "everything" before pressing the Scan button. After that, click on "Next>" and select "Save" and then, attach the .txt file.
Jocelyn M.
Jocelyn_Intel
Hello, @Ntardif
We are checking this thread and we would like to know if you were able to review our previous post. If you need further assistance, please do not hesitate to contact us back.
Jocelyn M.
n_scott_pearson
Here is where I found it (Zoom Video Settings).
Ntardif
Sorry about the slow response! Here is the scan file and a screenshot of it using an Intel driver. This is the same driver that gets auto installed from Windows update for this camera.
Jocelyn_Intel
Hello, @Ntardif
No worries, thank you for the information provided.
Please allow me some time to do some research on this. As soon as I have updates, I will let you know.
Jocelyn M.
Jocelyn_Intel
Hello, @Ntardif
Thank you for your time.
Device naming is placed based on OS-device compatibility and drivers, we recommend you to contact your System Manufacturer for assistance as the best way to proceed.
This thread will no longer be monitored, but if you need further assistance with other matters, please feel free to contact us back and submit a new post.
Have a nice day.
Jocelyn M.
