22828 Discussions
When i use my Intel UHD Graphics, so laggy
northencat
The problem is whenever i use the gpu, it's lagging my laptop pretty hard. and suddenly my HDD usage up to 100%
like when i use hardware acceleration, or opening games, or using camera like zoom
i tried to update driver it doesnt work
i tried to reinstall with clean windows 10, still same
i've tried many ways but the problem is still
My Spec Laptop is :
i5-1035G1 1 ghz (8cores)
Intel UHD Graphics (there's no version on dxdiag)
4 GB Ram
HDD 1 TB
any idea how to fix it ? please help me 🙂
David_G_Intel
Hello northencat
Thank you for posting on the Intel️® communities. To investigate, please share with us the Intel® System Support Utility (Intel® SSU) results
David G
northencat
here's the results of detailed view from intel ssu
northencat
Oh yea, new informartion. When i playing games, its always stuttering fps idk why. Any solution ?
David_G_Intel
Thank you for the report northencat. To provide the best recommendations please share with us the following info:
  • Does this happen with a specific application?
  • You mentioned that you tried to update the driver but "it doesn't work". Do you get a specific error? What method do you follow for the driver update?
  • Did you try different drivers? What versions did you try?
  • Did you try the drivers from Asus and Intel?
  • If possible, please share a video example of the problem.
David G
David_G_Intel
David G.
northencat
Sorry i was busy lately.
New info : my laptop going fine rn because i updates lastest graphic driver from intel not ASUS. and i upgrade my RAM from 4 GB to 8 GB.
David_G_Intel
We are glad to know you found a solution, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior. Since the thread is now solved, we will proceed to close it.
David G
