22750 Discussions
When you connect/disconnect power plug, the display will shortly switch off and refresh rate change
cursed-czar
I cannot find a dynamic refresh rate setting, when the plug is off refresh rate changes to 60hz which is annoying. please tell me what options I should change.
Jean_Intel
Hello cursed-czar,
We understand you have opened an email case with us and we will continue to help you through that channel now. We will therefore close this community case. Please keep in mind that this thread will no longer be monitored by Intel.
Best regards
Jean O.
hero22
I am facing the same problem.
Could you please tell me how to fix it?
Thank you in advance.
cursed-czar
I am using MSI laptop, so in the MSI app there was an option to disable this setting. I recommend you to go to your manufacture software and explore there is IGCC not helping.
