23281 Discussions
White squares hide the icon in the tree explorer in windows 10.
DDari4
How to get rid of white squares that obscure icons in the tree pane explorer in windows 10?
It does not help to remove IconCache.db.
A long time ago I had the same thing in Windows 98, and then it was a mistake graphics driver.
Driver Version: 20.19.15.4463
Operating System: Windows* 10 Pro (10.0.10240)
Default Language: Polish (Poland)
Physical Memory: 16246 MB
Vendor ID: 8086
Device ID: 0412
Device Revision: 06
Video BIOS: 2179.0
Current Resolution: 1680 x 1050
Hi T-H-L,
In regards to your case, could you send the results of Intel® System Support Utility, also let me know the Hz of your display and type of video cable that you are using.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?product=91600 https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?product=91600
Mike C
DDari4
Your request for service has been received.
We have received your request for support and we are currently processing your ticket. You should expect to hear from us within one business day.Your reference number is 01556652.
DDari4
DDari4
The problem occurs only when I do upgrade.
A clean installation gives the correct appearance of icons in Explorer.
My question to find ways to improve icons is up to date.
Hi T-H-L,
Pre-build systems require customized drivers by pc manufacturers such as Dell, Lenovo and similar companies. Our generic drivers usually don't work properly.
That's why the update is giving you graphic issues.
Mike C
