22690 Discussions
Why Is the Brightness Control Asymmetrical?
JWhy
hi
In HD Graphics Control Panel > Color > Basic > All Colors > Brightness:
When you change brightness, the colors are not changed equally-- the tint of my LCD screen changes. As i turn down the brightness, the screen becomes bluish. You can see the asymmetry in the Sample 1 Preview:
Why?
Is it possible to turn down the brightness on all colors equally?
Here are my display stats:
Intel(R) HD Graphics
Report Date: Friday, February 5, 2016
Report Time [hh:mm:ss]: 8:21:35 AM
Driver Version: 10.18.10.4276
Operating System: Windows* 10 Pro Insider Preview (10.0.10586)
Default Language: English (United States)
Installed DirectX* Version: 12.0
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.0
OpenCL* Version: 1.2
Physical Memory: 1939 MB
Processor: Intel(R) Celeron(R) CPU N2840 @ 2.16GHz
Processor Speed: 2167 MHz
Vendor ID: 8086
Device ID: 0F31
Device Revision: 0E
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics
Video BIOS: 1014.0
Current Resolution: 1366 x 768
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Built-in Display *
Display Type: Digital
Serial Number: SEC3859
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: Embedded DisplayPort
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 11.42 inches
Vertical Size: 6.3 inches
Supported Modes
1366 x 768 (60p Hz)
1366 x 768 (40p Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 4C A3 59 38 00 00 00 00
00 16 01 04 90 1D 10 78 0A 87 F5 94 57 4F 8C 27
27 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 CE 1D 56 F0 50 00 18 30 40 30
25 00 25 A5 10 00 00 19 D8 13 56 F0 50 00 18 30
40 30 25 00 25 A5 10 00 00 19 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02
00 0C 42 F2 0C 4C 64 15 10 1B 69 00 00 00 00 9F
* Other names and brands are the property of their respective owners.
thx!
Anonymous
Not applicable
Hi Johny Why,
I noted you have an Intel® Celeron™ N2840 with Intel® HD Graphics. The support for Windows® 10 is limited. The drivers are going to be distributed by Windows® 10 update only.
If you are getting issues with the brightness, I suggest you to uninstall and delete the current driver from device manager, restart the NUC and run Windows® 10 update.
In regards your question, "Why Is the Brightness Control Asymmetrical? " I am going to escalate it with our graphics engineer. I will try to get an answer soon.
Mike C
Anonymous
Not applicable
Hi Johny Why,
The Brightness Control can work in both "Symmetrical" and "Asymmetrical" ways.
The key here is the following control:
Under "Color Enhancement", by default "All Colors" is selected.
If you move the controls below, specifically the Brightness, the change will be done "Symmetrical" to all the colors. Note that the "Preview" example to the right should be a straight line.
However, if instead of using "All colors" you select either Red, Green or Blue, and then change the Brightness, the change will be done "Asymmetrical".
Please let me know if this answers your question.
Mike C
