22748 Discussions
Why does Fortnite get more laggy with each driver update?
blue114514
我的显卡 ARC A770 过去常常在最高设置下运行 Fortnite,在较旧的驱动程序版本上至少具有稳定的 100+ FPS。现在,即使打开最高设置和照明,它也勉强达到 40 FPS,并且偶尔会出现卡顿。
blue114514
My Windows version is 24H2, and my graphics card driver is6449. Currently, when playing Fortnite on Epic Games, I often experience stuttering. Despite having the same settings as before without any changes, the frame rate cannot stabilize
JeanetteC_Intel
Hello blue114514,
I need to get more details so I can further check the root cause of this issue. We have recently released new driver version Intel® Graphics Driver 32.0.101.6458. Please proceed with clean installation using Display Driver Uninstaller (DDU).
If the issue persists, please download and scan your system using Intel® System Support Utility for Windows* software so I can further check your system configuration for further checking. When the download is complete, launch SSU.exe.
  • Click Scan.
  • Click Save (.txt). Attach the file as you reply.
I will wait for your reply.
JeanetteC.
JedG_Intel
Hi blue114514,
I'm following up to see if you were able to perform the recommendations. Please let me know at your earliest convenience so we can determine the best course of action to resolve this matter.
Jed G.
JedG_Intel
Hello blue114514,
Jed G.
