22936 Discussions
Why is my Omen laptop running extremely slow without the charger?
ELafl1
A while back I bought a Omen Gaming laptop and i'm having some issue's.
Details:
Hp OMEN 15-dh0xxx
16GB RAM
Intel I7-9750H 2.6Ghz
Nvidia RTX 2060, 6GB
512GB SSD
1TB HDD
When playing games, editing videos, or doing any other task I noticed a severe drop in performance when unplugging my charger.
I know that using a laptop on the battery is always slower then when plugged in but the difference is way to extreme.
I did some benchmarks to confirm this:
Plugged in:
https://www.userbenchmark.com/UserRun/22500959
CPU:
  • Normal: 240fps
  • Heavy: 464fps
  • Extreme: 760fps
GPU:
  • 3D DX9 : 260fps
  • 3D DX10: 220fps
battery:
https://www.userbenchmark.com/UserRun/22500813
CPU:
  • Normal: 134fps
  • Heavy: 370fps
  • Extreme: 550fps
GPU:
  • 3D DX9 : 28fps
  • 3D DX10: 6fps
The drop in performance i see in the CPU is around what i'd expect when comparing battery to plugged in, so no issue there.
However the drop in GPU performance is off the charts, dropping from 220fps to 6fps is something i've never seen before.
When playing games (for example witcher on max settings) i can play on 60fps without any issue, i unplug the charger and it drops to 4fps.
I've updated all my drivers, manually and with the intel driver manager. (including bios). I've changed my power management settings to performance on max even on battery, but i notice no difference.
I've played around with the Nvidea settings, but no change there either.
Even with this bad performance the battery doesn't last too long, however i was aware of the short battery life on the laptop before i bought it, but i expected it to perform acceptable.
I'm out of ideas and don't know what to do about this.
Sorry if this is on the wrong Forum section, wasn't sure where to post this.
Kind regards.
n_scott_pearson
This is a good question -- for HP. This is their laptop design and their BIOS' ACPI tables manage the decision-making for power management. You need to be asking them about their design.
ELafl1
That would be great if they'd bother to answer...
n_scott_pearson
Gee, considering that you actually paid for this service as part of your laptop purchase, I would be a bit pi$$ed with their lack of support. Should your next laptop come from HP? I think not...
I detest Dell too, BTW (I am an equal opportunity detester).
