Hi, I have UHD Graphics 630 of motherboard B365M-HDV, with Windows 10 x64.
If I don't install the drivers of the integrated video card my monitor displays the colors perfectly, but I if install the drivers the monitor displays in black and white, this problem happen only I use monitor with hdmi attack, not if I use monitor with vga attack.
Why the monitor with HDMI connection is displayed in black and white by installing the drivers ?
How can I solve the problem?
Use a better HDMI cable, update the bios, and use the drivers from asrock (not the intel drivers).
Doc
I've tried everything (except bios update because the computer is new under warranty) but the problem remain
Update the bios anyway. I have seen "new" computers with a bios that is a year old.
Doc
You can try this newer version of the driver (*much* newer than what ASRock makes available): https://downloadcenter.intel.com/download/29195/Intel-Graphics-Windows-10-DCH-Drivers?product=126790.
..S
I tried this driver ma the problem remain
Hello AMaio1,
If you need further assistance, please generate the following system report and attach it.
- DxDiag
- Go to Start > Run or Windows Key + R.
- On the Run prompt, type "dxdiag" then click OK.
- On the DirectX Diagnostic Tool window, click on Save All Information.
- Browse to a folder, type in a filename then click Save.
Also, please provide us with the monitor model number.
Wanner G.
A Contingent Worker at Intel
Hello AMaio1,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Wanner G.
