22654 Discussões
Why on Windows Update/Intel Corporation - Extension is showing 3 old Different Versions of updates?
Avie1889
Novato
13.921 Visualizações
Hi friends
As you can see on screenshot below, my Windows Update is showing Intel Corporation - Extension updating 3 different OLD versions simultaneously while latest version is updated and preinstalled on the system. What's logic behind showing updates of old 3 different versions while latest one is updated and why Windows Update is forcing or showing it on Windows updates information? It's annoying.
As you can see on attached images, DriverExplorer.exe (Git hub) is showing 3 unwanted Old drivers installed in attached image while latest one is preinstalled and updated.
Is it a glitch on Intel side or is it necessary to install old drivers as well? Because my new updated driver is working smoothly and this weird old drivers started appearing on Windows Update and getting installed from past few days despite of deleting them again & again.
I request Intel to look into this matter and stop sending updates of old drivers when newest one is installed and updated.
Avie 🙂
Lenovo - X1 Titanium (Type 20QA, 20QB) Laptop (ThinkPad) - Type 20QA - Model 20QA00A8US (with Intel evo)
OS: Windows 11 23H2 Build 22631.3296
14 Respostas
ACarmona_Intel
Funcionário
13.742 Visualizações
Hello Avie1889,
Thank you for posting in our Intel communities.
Upon researching, we have found this Microsoft link that is related to the issue that we have. Please check this Microsoft forum for a possible solution:
https://answers.microsoft.com/en-us/windows/forum/all/how-do-you-remove-an-update-from-the-list-of/b69d81f8-1e5d-4b5e-9473-8ef195e9d2a1
Furthermore, you may also check out the following links below, as they may also be helpful to resolve our issue:
Thank you, and have a great day ahead!
Carmona A.
ACarmona_Intel
Funcionário
13.675 Visualizações
Hello Avie1889,
We are checking in with you to know if you have already performed the troubleshooting steps that we have provided or if you have any additional queries. Please know that we would be happy to assist you if you have any.
Thank you, and have a great day!
Carmona A.
Avie1889
Novato
13.660 Visualizações
I tried everything. But it keeps updating old drivers and also keeps new driver. I'm giving up as there's no solution. Those old drivers are provided by Intel to Microsoft so blaming Microsoft on this issue is unfair. You have to coordinate with Microsoft and solve this issue. Even C Drive Intel folder shows 4 different version of same driver is installed.
LeonWaksman
Superusuário
13.653 Visualizações
Hi Avi,
You didn't tried everything. Please download an run the Microsoft Show or Hide Updates Troubleshooter and block the unwanted updates from Microsoft. This is the right way to do it.  More explanation here
Leon
Avie1889
Novato
Hi
Check here, 4 different versions installed of same driver.
Even i used Microsoft wushowhide to hide drivers but it keeps coming up on reboot.
ACarmona_Intel
Funcionário
13.533 Visualizações
Hello Avie1889,
Please generate an SSU report to help us further analyze important details on your system, such as the OS build number, graphics driver version, complete model of your system, etc. To generate the SSU report, please refer to the article How to Get the Intel® System Support Utility Logs on Windows. Please share with us the generated SSU.txt file.
By the way, after providing the SSU, I will raise our concern with our engineers.
Carmona A.
Intel Customer Support Technician
Avie1889
Novato
13.505 Visualizações
Thanks for your revert.
Attached is SSU.txt file as per your request.
Hoping to get solution soon.
ACarmona_Intel
Funcionário
13.397 Visualizações
Hello  Avie1889,
Thank you so much for providing us with your SSU.
I will now raise the issue with our engineers and post the response on this thread once it is available.
Have a fantastic day, and thank you very much for your patience and understanding!
Carmona A.
ACarmona_Intel
Funcionário
13.246 Visualizações
Hello Avie1889,
Thank you so much for patiently waiting on our response.
Upon reviewing the most recent SSU logs, it has been observed that the graphics driver version currently installed is 31.0.101.4314, which may be provided by the original equipment manufacturer (OEM). It is recommended to proceed with the installation of graphics driver version 31.0.101.5444. Following this update, kindly perform a Windows update once more and let us know the outcome.
Please note that during the installation of the graphics driver, it is important to ensure that the option for 'Execute a clean installation' remains unchecked.
Thank you and have a great day ahead!
Carmona A.
ACarmona_Intel
Funcionário
12.896 Visualizações
Hello Avie1889,
Carmona A.
Avie1889
Novato
12.728 Visualizações
I have done what you have instructed. I installed latest Graphics driver, deleted old versions and reboot. But now i have another issue. I am unable to get windows updates as you can see on screenshot attached.
ACarmona_Intel
Funcionário
12.578 Visualizações
Hello Avie1889,
Thank you so much for the update.
I just wanted to confirm: did the initial problem with the outdated drivers continually getting installed get fixed after you used the troubleshooting steps we provided? And after that, there was a new problem that prevented you from receiving Windows updates. Is this correct?
Carmona A.
ACarmona_Intel
Funcionário
12.247 Visualizações
Hello Avie1889,
Again, I just wanted to confirm: did the initial problem with the outdated drivers continually getting installed get fixed after you used the troubleshooting steps we provided? And after that, there was a new problem that prevented you from receiving Windows updates. Is this correct?
Carmona A.
ACarmona_Intel
Funcionário
11.857 Visualizações
Hello Avie1889,
We have not heard back from you, so we will close this enquiry now. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
By the way, if the issue still persists, we also highly advise that you contact your system manufacturer for further assistance.
Thank you, and have a great day ahead.
Carmona A.
Responder
