I've been having a lot of crashes and lag running chrome and browser games lately, so I caught a few clips of it happening to make it clear what I'm experiencing.
Could anyone offer some advice? I can't overclock, and I'm using a windows 10 laptop.
Hello noobifiod
From the information provided, we see that the system has some updates pending. You're using the latest Intel graphics driver but we recommend the customized drivers provided by the laptop manufacturer, you can update the drivers yourself with the ones on their website or your can contact the support. We recommend checking with their support for the updates since your BIOS is also not the latest and this is something only they can determine if it's necessary and help you with it.
In case that the issue persists after the updates, please share with us the following:
- Does this happen with other applications?
- Did you complete all Windows updates?
- Which version of Chrome do you use?
- Does this same thing happen with other browsers?
- Did it work properly before? If it did, what changed on your system?
David G
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
[Windows 11 is the new Vista]
Hello noobifiod
David G
David G.
David G.
![](/skins/images/E799062D82CA2A220ED12C6FD1960495/responsive_peak/images/icon_anonymous_message.png)
