22676 讨论
Windows 11 Installation during showing BSOD
DKveer
初学者
10,864 次查看
Dear Sir Please resolve the problem my New graphics card inter ARC 750, Few days purchase and first installation windows 11 chased installation with blue screen showing may time.
Please needful
0 项奖励
18 回复数
Andres_Intel
员工
10,835 次查看
Hello DKveer,
Thank you for posting on the Intel®️ communities. I know it is very annoying when having Blue Screen of Death (BSOD) with the Intel® Arc™ A750 Graphics, I am more than glad to help you.
To have a better idea of the issue and then start with the next steps, please answer the following questions:
Andres P.
0 项奖励
DKveer
初学者
10,814 次查看
Dear Sir,
Please check of attachments and resolve my problem
0 项奖励
Andres_Intel
员工
10,792 次查看
Hello DKveer,
Thank you for your response and for sharing the picture and SSU report.
I see in the report that you have installed at this moment Windows 10. Just to clarify, when you try to install Windows 11, the BSOD pops up is that correct? Or you were able to install it but once you do it you receive the BSOD, is this the way how the BSOD shows up.
Andres P.
0 项奖励
DKveer
初学者
10,774 次查看
Dear Sir,
I have Install windows 10 but BSOD showing any time in windows 10, like a game play and other activities
I have update BIOS but problem is continue. i am very disappointed. Intel ARC A750 Graphic Card.
Please resolve my problem.
0 项奖励
Andres_Intel
员工
10,761 次查看
Hello DKveer,
Thank you for your answer, and clarification, that helps a lot.
Please follow the steps below and let me know if the behavior changes:
Andres P.
0 项奖励
DKveer
初学者
10,744 次查看
Dear Sir,
I have installation BIOS version 1212, and your solution tips Latest Graphics 31.0.1014824, i have installed latest version but problem not resolve and new issue create ARC Control has been not open, and graphic card over heating problem generate after new release graphics driver update and my big issue BSOD is continue.
Please resolve my problem because i am very disappointed with intel ARC.
Screen Shot Attached
0 项奖励
DKveer
初学者
10,728 次查看
Dear Sir,
I have installation BIOS version 1220
not 1212
0 项奖励
Andres_Intel
员工
10,718 次查看
Hello DKveer,
Thank you for your reply, all the information provided has been really helpful.
I am sorry to hear that now Arc Control does not open and the GPU is overheating after the graphics driver update, to keep this thread organized and help you in the best way, please open a new thread per issue, we will be more than glad to help you
I will start with an investigation and as soon I have further information I will let you know
Andres P.
0 项奖励
Andres_Intel
员工
10,625 次查看
Hello DKveer,
Thank you for your time.
We have been working on the investigation, and now I have a couple of questions:
  • Are there errors/yellow bangs in the device manager? If so, take screenshots of it.
  • Is the Resizable Bar enabled?
  • Did the issue happen right after updating to W10?
  • Was the system working well at any point?
  • Are you using DisplayPort or HDMI? Let me know if thee issue happens in both ports
Andres P.
0 项奖励
DKveer
初学者
10,605 次查看
Dear Sir,
As per your demand i have sent screenshots of Device Manager and Resizable Bar on i seen in Motherboard BIOS.
Screenshot attached and my next issue create grachics card Vram tempareture high and FPS very low and games legs GPU utiligation like a 90 % and CPU utiligation 25 % i am very confuse GPU & CPU utiligation is very difference and BSOD error showing continue after 30 min. or 1 hour sometime.
Please solve my multiple issues.
0 项奖励
Andres_Intel
员工
10,582 次查看
Hello DKveer,
Thank you for your for all the information provided, that helps a lot.
Previously I asked some questions but seems they were not answered, please find them below to have a better understanding of the issue:
Please keep me informed of the results.
Andres P.
0 项奖励
DKveer
初学者
10,552 次查看
Dear Sir,
As per your questions details mention below
Resizable Bar is enable
Win 10 BSOD and GPU bottlenecking issue showing from day first
Basis task is normal but gaming and heavy task is not working Proper
I am using HDMI port only and other port is not try me.
I am installing a New driver then after share with you PC performance days evening
Screenshot Attached
Resizable Bar is enable and GPU bottleneck
Sir Please very humble request for you resolve my problem.
0 项奖励
Andres_Intel
员工
10,527 次查看
Hello DKveer,
Thank you for your clarification, that is very helpful.
Now I will continue with the investigation, to provide you with the next steps as soon as possible.
Andres P.
0 项奖励
Andres_Intel
员工
10,446 次查看
Hello DKveer,
Thank you for your patience.
We have been working on the investigation, based on the image it looks like there are some drivers missing, please contact the Motherboard Manufacturer to make sure those drivers are properly installed. Those drivers are usually on the Motherboard website, however, it is better to make sure with them which are the ones you actually need.
I will wait for you to make sure the BSODs won't come back. Let us know the results after that.
Andres P.
0 项奖励
DKveer
初学者
10,360 次查看
Dear Sir,
My BSOD problem solve because i were replease RAM (Rendon Access Memory) foulty then after i am clean windows 11 installation done and work well but my GPU performance is poor because gaming performance weak, game lagging, medium setting, but game performance not stable and high setting game create overheating and highend use of Vram and high temperature run in game fortnite and Call of duty medium setting.
0 项奖励
Andres_Intel
员工
10,306 次查看
Hello DKveer,
Thank you for letting me know about it.
Happy to hear that the BSOD issue was fixed by replacing the RAM. Related to the game performance issues to keep this thread organized and help you in the best way, please create a new thread, and we will be more than glad to help you.
Let me know if you have further questions.
Andres P.
0 项奖励
DKveer
初学者
10,206 次查看
Dear Sir,
Please find the attached videos of during game play Call of Duty game.
CPU, GPU & Memory Utilization Details
CPU Activity                         6%
Memory Utilization               85%
GPU Memory Utilization      96%
GPU Temperature                71 C
GPU Activity                         99%
VRAM Temperature             78 C
Render Activity                     98%
Please see the details and solve these issues.
0 项奖励
Andres_Intel
员工
10,179 次查看
Hello DKveer,
Thank you for letting me know about this issue with Call of Duty.
I understand this may not be a normal behavior of the graphics card and I know that this can be frustrating for you. Since this thread is related to BSOD issues, please open a new thread related to the high GPU usage, we will be happy to help you.
For now, we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
0 项奖励
回复
