23257 Discussions
Windows 8.1 - HD4000 - DirectX No longer working
MSt-G1
I am in a bit of a jam right now and can't think of any more solutions to this problem here is what I have tried:
- Installing the Beta driver for Windows 8.1, result: Driver doesn't work (code 43), windows reverts to basic driver. Direct X works but is software emulated.
- Installing manufacturer Drivers (9.17.10.2843). Driver seems OK, Direct X doesn't work, dxdiag reports no errors however.
- Installing another Intel Driver (9.18.10.3071). Same result
- sfc /scannow reports no errors
Here is my current dxdiag output:
System Information
Time of this report: 8/24/2013, 21:50:31
Machine name: CSL-AM-CF53
Operating System: Windows 8.1 Pro Preview 64-bit (6.3, Build 9431) (9431.winmain_bluemp.130615-1214)
Language: English (Regional Setting: English)
System Manufacturer: Panasonic Corporation
System Model: CF-53JALRYRM
BIOS: V2.05L11
Processor: Intel(R) Core(TM) i5-3320M CPU @ 2.60GHz (4 CPUs), ~2.6GHz
Memory: 4096MB RAM
Available OS Memory: 3958MB RAM
Page File: 2821MB used, 2352MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.03.9431.0000 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0166&SUBSYS_833810F7&REV_09
Display Memory: 1792 MB
Dedicated Memory: 32 MB
Shared Memory: 1760 MB
Current Mode: 1366 x 768 (32 bit) (58Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: MS_9003
Native Mode: unknown
Output Type: Internal
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 9.18.0010.3071 (English)
Driver Version: 9.18.10.3071
DDI Version: 11
Feature Levels: 11.0,10.1,10.0
Driver Model: WDDM 1.2
Graphics Preemption: DMA
Compute Preemption: Thread group
Miracast: Not Applicable
Hybrid Graphics GPU: Not Applicable
Power P-states: Not Applicable
Driver Attributes: Final Retail
Driver Date/Size: 3/19/2013 21:31:48, 8647680 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4226-11CF-BD72-35A3A2C2C535}
Vendor ID: 0x8086
Device ID: 0x0166
SubSys ID: 0x833810F7
Revision ID: 0x0009
Driver Strong Name: oem0.inf:5f63e5341859ec8c:iIVBM0:9.18.10.3071:pci\ven_8086&dev_0166
Rank Of Driver: 00E02001
Video Accel:
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
Deinterlace Caps: n/a
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Not Available
D3D Status: Enabled
AGP Status: Not Available
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0269&SUBSYS_10F70500&REV_1002
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.6649 (English)
WHQL Logo'd: Yes
Date and Size: 5/31/2012 04:24:14, 4064272 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Wireless Switch for Panasonic PC
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x04AD, 0x26FF
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x1E2D
| Matching Device ID: USB\ROOT_HUB20
| Service: usbhub
| Driver: usbhub.sys, 6/15/2013 22:32:49, 488712 bytes
| Driver: usbd.sys, 6/15/2013 22:32:49, 28432 bytes
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0024
| | Matching Device ID: USB\Class_09
| | Service: usbhub
Gameport Devices
PS/2 Devices
+ Standard PS/2 Keyboard
| Matching Device ID: *PNP0303
| Service: i8042prt
| Driver: i8042prt.sys, 6/15/2013 20:35:26, 107520 bytes
| Driver: kbdclass.sys, 6/15/2013 22:33:29, 54536 bytes
DArce
Valued Contributor III
Thank you for your feedback on this matter. We have provided an Intel Communities Forum to discuss your experiences with the preview driver program for Window 8.1* Preview here
http://communities.intel.com/community/tech/windows_8.1preview_feedback http://communities.intel.com/community/tech/windows_8.1preview_feedback
Please go ahead and post or find a similar issue on this section and follow the recommendations available there.
