22672 Discussions
Windows 8.1 none intel driver works with HD4600
ZStan
4 040 Visites
Just updated from windows 8 pro to 8.1 (from msdn student version) and NONE driver (newest from intel site (15.31.17.64.3257 (9.18.10.3257)) for win8 nor driver from asus (VER918103262_x64) for 8.1) did not work, i just get driver could not start error code 31, also tried driver from windows update which is newest of all and that one is also no go!
I have
Asus Z87-A (newest bios)
i5 4750
win8 x68
intel HD 4600 is primary conected to 2x monitors
+ 2x 7950 ATI used for GPU computing
Restored back windows 8 imagine so i could use PC!
0 Compliments
8 Réponses
DArce
Précieux contributeur III
2 494 Visites
I suggest that you check the information available on this article:
0 Compliments
ZStan
2 494 Visites
Ok i tried again five different drivers from Intel none go, all get disabled after restart, then i tried tracking down whats the cause of it and i faund there is compatibility problem with ATI catalist (13.10 and 13.11) as soon i install them, ATI driver works but intel driver stops... also playing with ATI drivers i got bunch of bsod`s due it...
So Windows 8.1 intel GPU and ATI 7950 is no go, i have 2x 7950 used only for opencl (bitcoin mining) and intel HD is primary with 2 monitors attached
PS: I am using win 8 had no issue at all with ATI+Intel combo with any driver i used so far, and i used most drivers released from ctalist 12.6 to 13.10 and almost all intel drivers
0 Compliments
mdav
Débutant
2 494 Visites
8.1 upgrade problems too. The upgrade actually dies and reverts... Try to upgrade to 8.1 and the screen goes black. Have to revert.
Tried downloading the 8.1 compatible driver (64 bit) and it says my system did not met the minimum requirements.... This is a beefy HP Envy 23 - inexcusable that they don't support this new machine from HP.
This is a really nasty bug with the black screen and there is no solution for me right now. Not good.
Please advise asap.
0 Compliments
entilza
Nouveau contributeur I
2 494 Visites
I think I read somewhere regarding the black screen during upgrade that you just have to wait it out? How long have you waited?
0 Compliments
DHunt8
Débutant
2 494 Visites
I am running Win 8.1 64bit on an ASUS Z87-Pro (running the HD4600 gpu) which was working fine with windows 8. MS released an updated driver on the 19th that corrected the issue for 3 days, but now the driver is failing again with the same error Code 31.
It would be wonderful if Intel could push a new driver into the download area!
Here's a thread on the windows community for this issue:
http://answers.microsoft.com/en-us/windows/forum/windows8_1_pr-hardware/intel-hd-4600-driver-issue-code-31-with-windows-81/e42f56e6-42ac-4f5b-8f3b-4e1b3abf0802 Intel HD 4600 driver issue &# 40;Code 31&# 41; with Windows 8.1 - Microsoft Community
0 Compliments
DArce
2 494 Visites
Please try the suggestions posted on this thread and provide any constructive feedback on that thread we have created for this purpose
0 Compliments
DBaer
Débutant
2 494 Visites
I have an HP Envy 17 j0000 with the i7-4900MQ and the NVidia GT470M 16GB Ram running Windows 8.1 Pro x64 After updating to Windows 8.1 and installing the latest driver from Intel I'm getting exactly the same error. Thankfully the NVidia driver is working so the machine is usable all be it limping along on a single display for now. Looks like there will be an avalanche of broken machines out there till its fixed.
0 Compliments
ZStan
2 494 Visites
I manged to fix the error, prior to upgrade I deinstaled intel and ATI driver (also used some tool to clean ATI crap)... after update to 8.1 i installed first intel beta driver 15.33.5.64.3316 by manual method with have disk... and only after that i put latest catalist 13.1 beta 6 (only driver) so far so good...
Duno whos to blame ati crap driver or intel one
Répondre
