22970 Discussions
Windows 8.1 (x86) Tablet w/ Atom Z3735F blank screen after wakeup
ENyma
Hello.
I just treated myself with a very nice Windows tablet a couple of days ago. After doing a clean install and getting all the drivers in place, I noticed something funny: after going into sleep mode, the screen would refuse to wake up. The backlighting fires up normally, but I'm not getting any sort of output at all. Pressing the power button again (which makes it go into sleep mode again) and waking it up repeatedly results in the exact same thing.
Now, the more interesting thing is that it only happens with the Z3700-series drivers installed. Without them, thus using some sort of "Generic" driver from Windows, the screen "dies" and actually wakes up from the sleep mode, with the exception being that the backlight is still on when it goes to sleep. After reinstalling the drivers again, the previous problem occurs. I've tried older drivers, tried changing power settings and so on. After a bit of browsing I've noticed there are quite a few with the "black screen" problem, though I'm unsure if it's any similar to this, as it only occurs after trying to wake the device up (everything but the GPU wakes up by the looks of it, I've got sound and everything.).
Another thing to mention would be that I can't set Windows to only turn the screen off; it'll automatically change the "sleep after" -setting to the specified time as well.
Any known workarounds for this? I'd rather not have the tablet sit on all the time, and have to power it off and on repeatedly.
Allan_J_Intel1
Make sure you have loaded the latest graphics drivers using below links:
https://downloadcenter.intel.com/download/24826/Intel-HD-Graphics-Driver-for-Windows-7-8-8-1-64-bit Intel® HD Graphics Driver for Windows* 7/8/8.1-64-bit
https://downloadcenter.intel.com/download/24825/Intel-HD-Graphics-Driver-for-Windows-7-8-8-1-32-bit Intel® HD Graphics Driver for Windows* 7/8/8.1 32-bit
Before you install video drivers, try uninstalling any Intel(R) Graphics Driver from windows control panel.
Allan.
ENyma
Hello
I've already performed this step many times now, unfortunately without success.
As I wrote earlier, the backlight starts, just as most screens when they wake up. However, I'm not getting any graphical output at all. Do you think it may be a BIOS setting? Or maybe a power setting?
Allan_J_Intel1
BIOS or power settings within windows control panel might be an option; however, I am not familiar with your Tablet model. You need to contact your Tablet manufacturer for further instructions.
I also recommend getting customized drivers from the tablet maker as the graphics driver engine may be different from our versions.
Allan.
