22647 Discusiones
Windows XP (32 bits) driver video for Dell Optiplex 390 and sound Tag 80R14V1 (error 0x80071ec - Asie)
MLama3
Principiante
9.506 Vistas
Greetings
I have a Dell Optiplex 390, for the compatibility with at least a very big important printer and certain applications, I need to install Windows XP in this machine, but the audio does not work and especially the video is fashion standard VGA, none pilots(drivers) DELL for this one for XP of 32 bits but for W7 of 64 bits a driver GMA INTEL HD
I tried the driver of Dell download of Dell .pourtant it was indicated for XP
I have Windows XP 32 bits SP3 in French installed in these machines.
Please to help at least if I little to have the video standard VGA it is 30 % of the difficult screen has read lira there was certainly a video driver for XP of 32 bits Windows Home or PRO
By Piriform Speccy
Motherboard
Manufacturer Dell Inc.
Model 0M5DCD (CPU 1)
Version A00
Chipset Vendor Intel
Chipset Model Sandy Bridge
Chipset Revision 09
Southbridge Vendor Intel
Southbridge Model H61
Southbridge Revision B2
Intel HD Graphics
8009640C (1360x768@60Hz)
Intel HD Graphics (Dell)
Manufacturer Intel
Model HD Graphics
Device ID 8086-0102
Revision A
Subvendor Dell (1028)
Current Performance Level Level 0
Current GPU Clock 847 MHz
Technology 32 nm
Driver version 9.17.10.4459
Count of performance levels : 1
Level 1 - "Perf Level 0"
GPU Clock 847 MHz
Audio
Sound Cards
Son Intel pour écrans
Conexant SmartAudio HD
Playback Device
Haut-parleurs (Conexant SmartAudio HD)
from Xp (32)
Intel Driver and Support Assistant Installer
and log
Intel®_Driver_&_Support_Assistant_20171211131251
read from Windows 7 (64) an other Windows in this PC
Intel® HD Graphics
Adapter Compatibility
Intel Corporation
Video Processor
Intel® HD Graphics Family
Resolution
1360 x 768
Bits Per Pixel
32
Number of Colors
4294967296
Refresh Rate - Current
60 Hz
Refresh Rate - Maximum
75 Hz
Refresh Rate - Minimum
59 Hz
Driver Provider
Intel Corporation
Driver Version
9.17.10.4229
Driver Date
26/05/2015
Adapter DAC Type
Internal
Adapter RAM
1,76 GB
Availability
Running at full power
Status
This device is working properly.
Location
PCI bus 0, device 2, function 0
Device Id
PCI\VEN_8086&DEV_0102&SUBSYS_04F51028&REV_09\3&11583659&0&10
But I can only video standard VGA in Xp please hepl me
join Intel®_Driver_&_Support_Assistant_20171211131251
Thank you
0 kudos
4 Respuestas
Stefan3D
Colaborador Distinguido II
7.961 Vistas
https://downloadcenter.intel.com/fr/download/22642/Intel-HD-Graphics-Driver-for-Windows-XP-exe- Télécharger Pilote du contrôleur graphique Intel® HD pour Windows XP* (exe)
Version : 14.51.11.5437 (Les derniers)
MLama3
Principiante
7.961 Vistas
Thank you Stefan3D
 It is the good drivers video it so important thank you
now the drivers for sound
and error 0x80071ec - Asie
Driver Provider
Conexant
Device Id
HDAUDIO\FUNC_01&VEN_14F1&DEV_50A1&SUBSYS_102804F5&REV_1001\4&26FC5984&0&0201
Son Intel® pour écrans
Driver Provider Intel® Corporation
Device IdHDAUDIO\FUNC_01&VEN_8086&DEV_2805&SUBSYS_80860101&REV_1000\4&26FC5984&0&0301
Stefan3D
7.962 Vistas
MLama3
Principiante
7.962 Vistas
Thank you Stephn3D
Greetings
Now the video is ok
There is two audio pilots Connexian and other intel, the first one has the intallation seem to go, we have that of Intel probably
There is also? In the gestionaire has bus controller SM
and to the audio controller on audio bus High Definition
Thank you
Responder
