- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Hi, first sorry for my english
My system specs :
Core I7 3770k
Asus P8Z77-V
Radeon HD 7950
Windows 7 x64
I bought a Core I7 3770K and a Z77 mother board (Asus P8Z77-V) a few days ago, and i wanted to use "Intel Quick Sync" HW acceleration for video encoding, but when i got both "AMD Catalyst Control Center" and "Intel HD Graphics" installed on my computer, windows do not boot anymore, and stay stuck at the boot animation, i have to manualy remove drivers from the Windows Safe Mode to have my PC booting again ...
I found a lot of people having this kind of issues, but i don't find any solution 😕
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
The reason you are not able to boot into the operating system is because you installed our graphics generic driver from out Intel site, using a Radeon HD 7950 and our Intel® HD Graphics 4000 together.
To fix your issue I recommend you install the latest graphics driver from your motherboard manufacturer from the following support link:
http://www.intel.com/support/oems.htm Computer Manufacturer Support Web Sites
For more information regarding Switchable Graphics please go to the following URL:
http://www.intel.com/support/graphics/sb/CS-031103.htm Graphics — Switchable Graphics feature FAQ
Michael
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Intel, Michael
I have the same problem as HoM3r. I have a ASUS Z77 motherboard, and a Sapphire HD 7950 Graphics Card. When I installe the ASUS HD 4000 driver while have the ATI catalyst software installed, I only get to Win7 boot Graphics, and then the boot does not continiue.
I can then deativate the HD 4000 driver in safe mode, and then win7 will boot.
Can you help?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
You will also need to get the graphics driver from Asus* at the link below since our generic drivers will not work with your configuration:
http://www.intel.com/support/oems.htm http://www.intel.com/support/oems.htm
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I have the same problem, or similar. I have an ASUS P8Z77-V DELUXE Motherboard and a i7 3770K processor. I have been using my PC with an Nvidia video card, but if I remove it, when I turn on the PC it starts rebooting indefinitely, Windows 7 does not seem to even start loading (because I don't see the logo and if I press F8 to get the boot options I get nothing).
I have tried uninstalling/reinstalling the video drivers, at first I was getting an error "This computer does not meet the minimum requirements", then I managed to install it. But the problem persists.. when the NVidia card is installed I can boot and once in windows both cards work. But if I remove the discrete card or If I configure the BIOS to boot with the integrated card then I cannot boot.
-Jonathan
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
You will need to contact Asus* to make sure you are choosing the right options in the BIOS, and also for you to get the graphics drivers specifically build for your system at the link below:
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Michael,
I am in fact using ASUS drivers, the latest version downloaded from the https://www.asus.com/Motherboards/P8Z77V_DELUXE/# support_Download_30 web. In fact, after uninstalling ALL the video drivers I got to boot from windows.. but I get a 640x480 resolution from the default VGA driver.. The device manager shows the Intel HD Graphics 4000 with the following error: "The device cannot find enough free resources that it can use. (Code 12). If you want to use this device, you will need to disable one of the other devices on this system."
I haven't been able to get through this error.
-Jonatan
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
From what I can read from the error is that you cannot use your system with switchable graphics. You need to either use the Intel(R) on-board graphics or the Nvidia video card, but not together. This is the reason that is best if you contact Asus* for support.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
i have same type of problem
here is my laptop specification:
lenovo edge e430
3254cto
i3-2350m cpu @2.30
intel hd 3000
Recently I change my hard disk (western digital). After installing windows 7 (64bit) everythings fine as long as i didnt install display driver (intel hd 3000). Installing the driver and after restart, windows didnt bootup and start flickering, so i entered windowns with safe mode and uninstall the hd3000 driver and everything fine again. I tried several time and same thing happen. Tried the latest driver from intel and lenovo both web, and find the same result.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
What are the specific driver versions you are testing with?
Did you update the BIOS for the lenovo edge e430 system you have?
In addition, please post the dxdiag report from that system
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Diego_Intel.
heres more info.....
thank you for your help.
Intel HD Graphics Driver (from lenovo web)
Versions 8.15.10.2778 (Graphics Driver)
6.14.0.3090 (HD Audio Driver)
yes, i already update the BIOS for the lenovo edge e430, which is--
"IOS Update Utility_Version 2.54"
_____________________________________
______________DxDiag report___________
System Information
Time of this report: 9/10/2013, 19:53:53
Machine name: Z
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_rtm.101119-1850)
Language: English (Regional Setting: English)
System Manufacturer: LENOVO
System Model: 3254CTO
BIOS: Phoenix BIOS SC-T v2.2
Processor: Intel(R) Core(TM) i3-2350M CPU @ 2.30GHz (4 CPUs), ~2.3GHz
Memory: 4096MB RAM
Available OS Memory: 3686MB RAM
Page File: 1224MB used, 6144MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Standard VGA Graphics Adapter
Manufacturer: (Standard display types)
Chip type: Intel(R) Sandybridge/Ivybridge Graphics Chipset Accelerated VGA BIOS
DAC type: 8 bit
Device Key: Enum\PCI\VEN_8086&DEV_0116&SUBSYS_500017AA&REV_09
Display Memory: n/a
Dedicated Memory: n/a
Shared Memory: n/a
Current Mode: 1366 x 768 (32 bit) (1Hz)
Monitor Name: Generic PnP Monitor
Monitor Model:
Monitor Id:
Native Mode:
Output Type:
Driver Name: vga
Driver File Version: 6.01.7600.16385 (English)
Driver Version: 6.1.7600.16385
DDI Version: unknown
Driver Model: unknown
Driver Attributes: Final Retail
Driver Date/Size: 7/14/2009 05:38:47, 15360 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4256-11CF-1B34-B06DA7C2CB35}
Vendor ID: 0x8086
Device ID: 0x0116
SubSys ID: 0x500017AA
Revision ID: 0x0009
Driver Strong Name: Unknown
Rank Of Driver: Unknown
Video Accel:
Deinterlace Caps: n/a
D3D9 Overlay: n/a
DXVA-HD: n/a
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
Sound Devices
Description: Speakers (High Definition Audio Device)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_14F1&DEV_506E&SUBSYS_17AA5000&REV_1000
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 6.01.7601.17514 (English)
WHQL Logo'd: Yes
Date and Size: 11/21/2010 09:23:47, 350208 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Description: Microphone (High Definition Audio Device)
Default Sound Capture: Yes
Default Voice Capture: Yes
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Please test the driver posted here:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23102&lang=eng https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23102&lang=eng
Or you can also test this previous version:
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
hi Diego_Intel,
thank you, try both version but not working.
thanks.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Try to force the generic driver by uninstalling the driver that was provided by your laptop manufacturer or any other video driver that may be still installed through the Control Panel, go to programs and features, then locate any entry similar to Intel® Graphics Media Accelerator or video driver and remove it. After that, restart your system and try to install the generic driver again with the instructions on this site:
http://support.intel.com/support/graphics/sb/CS-022355.htm http://support.intel.com/support/graphics/sb/CS-022355.htm
For this, use the driver posted here:
https://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/23102/a08/Win64_152818.zip&lang=eng&Dwnldid=23102 https://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/23102/a08/Win64_152818.zip&lang=eng&Dwnldid=23102
You may also want to use a registry cleaning software to make sure that there is no entries of a previous driver. And just to confirm, what is the video port you are using for this configuration? Have you tried using another video port if available? Or tested another video display possibly
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thanks again.
Uninstall all the driver, clean the reg by CCleaner. Install ur given link driver, same again!!!!
so here some quick question, (im not a technical person )
1) now...if i dont install any display driver, in device manage_display adapter dropdown its written "standard vga Graphics Adapter" and after intall the driver its written "intel(R) hd graphics 3000" (after restar windows not bootup n start flickering)
So is it possible that the internal agp part was damaged, but display working fine.
(I mean vga part working but 3d accelerator part not working.)
2) previously several time i install windows and use the same driver and everything was fine, all this mess right after my Toshiba HDD gone and i bought the Western Digital HDD, all i understand that should not a cause of the problem.
So what might be the problem.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
What you see in the Device Manager is completely expected as what Windows* installs is just a generic driver for your system.
Changing the hard drive should not represent in an issue in your system, however =, taking under consideration that this has started to happen after re-installing the operating system, and even using the drivers provided by your Original Equipment Manufacturer, you may need to test using another operating system image or try a separate operating system installation with no other than the drivers provided by your system manufacturer.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
